Question about Karcher 2500 PSI Pressure Washer
What type of oil to use on the karcher honda 5.0 hp engine. Basically, what weight, 5w30 or 10w30
4 Suggested Answers
SOURCE: Katcher pressure washer w/ 5hp Honda Engine
pour a bottle of carburettor or fuel injector cleaner in the fuel tank, replace the spark plug and set the spark pluglug gap at 0.7mm. Replace the air filter element. Also change engine oil if necessary (mobil 10w30 synthetic.
Posted on Feb 03, 2009
  • 34 Answers
SOURCE: What kind of oil does the karcher gas powered
10W30
Posted on May 16, 2012
  • 174 Answers
SOURCE: Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Posted on Aug 18, 2009
1991 Honda CR 250 what oil weight is reccomended
Engine/gear oil is either 10w40 or you can use light gear oil.if your talking about fork oil it's 5 weight .
Mar 14, 2015 | Honda CR 250 R Motorcycles
What kind/type engine oil for the 17.5 H.P. Troy-Built Pony garden tractor?
sae 30 weight is used for most garden tractor engines. This is straight 30 weight oil not a multigrade. Most big box stores that carry this kind of gear have it.
Feb 16, 2011 | Briggs & Stratton Briggs Stratton Intek V...
What weight oil does the honda 5.5 engine require?
Your Honda 5.5 hp engine specifically calls for SAE 5W30 engine oil. Use a good quality oil in the engine, and change it every 50 hours of run time. The pump will take 30weight non-detergent oil.
Using non-detergent oil in the engine will probably void your warranty, and will certainly shorten the life of the engine. Non-detergent oils have not been recommend by engine manufacturers in nearly 20 years.
Oil is cheap, go ahead and spend $4 - 5 on a quart of high quality oil. Your engine uses about 20 ounces per change.
Oct 01, 2010 | Honda 2500 PSI Gas Pressure Washer
WhaT TYPE OF OIL DOES THE 16.5 HP B&S engine take
Your 16.5 hp Briggs engine takes SAE HD30 weight motor oil. I recommend to use a name brand high quality oil. It should take 48 ounces from a complete drain. If you run this engine when it is cold outside (below freezing) then you can change to a 10W30 oil.
Good luck
Sep 16, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
What is the Recommended Oil Specification for a HONDA G300
hi. 15w40 for the honda engine. normal multigrade oil. in real low temps you can pick a 10 or 5 w good luck
Feb 14, 2010 | Karcher 2500 PSI Pressure Washer
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 520m oil leak
small engine shop should be able to obtain the proper gasket for you.....oil 20 weight fill untill you can see it at the bottom of the threads at the whole you pour it into!
May 24, 2009 | Karcher 2500 PSI Pressure Washer
What oil do i use
synthetic 30 weight is the proper oil
Dec 25, 2008 | 2005 Honda CRF 450 R
Karcher 2500 PSI Pressure Washer Logo
666 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
