Question about Onkyo LS-V955 System
Onkyo DR-S2.2 blink and shuts off
I own a DR-S2.2 and for some reason my unit blinks and shuts off. I have tried to plug it in by itself and in different socket but it does the same thing no matter where I plug it in. I checked the fuses and they were fine please help
  • 2 more comments
  • BruceTman Jul 16, 2008
    I was watching and BAM! It now won't go off standby. The manual's troubleshooting says that the amplifier protection circuitry has been activated and to contact an Onkyo service center. There must be a workaround for this.
  • marc h Jan 11, 2009
    I have the same issue. Were you able to get it fixed?
  • isbroken Jan 21, 2009
    My system, Onkyo DR-S2.2, plays for a few minutes and then pops and goes to standby. I have not found a solution yet.
  • Anonymous May 13, 2009
    Mine does the exact same thing. When I turn it on it stays on for about 5 seconds then shuts off and there is a red light that just blinks. PLEASE HELP.
    Problem Solver:
  • 11 Answers
Most common failure is the audio amp IC, reference # Q5001, which is an STK402-950 (Onkyo Pt. # 222123). Typically fails as a result of excessive volume levels or as a result of problems with the speakers or their wires. If you're technically inclined, the part can be had from various vendors & is fairly straightforward to replace once the complex disassembly required to access the PCB this IC resides on is accomplished, using standard soldering skills. A repair of this type by a reputable servicer may be more effective for non-technical folks, as typically can be accomplished for $200 or less, much less than replacement cost...
Posted on Oct 27, 2009
  • harmon98 Jan 09, 2011
    That seemed to be the offender in my case. I gave that STK402-950 the Arthur Fonzerelli with the back of the screwdriver, and it went right back to perfect working order! (Of course, this is in NO WAY the proper resolution, but I'll take it for as long as it will last!)
    Thanks for the tip!
2 Suggested Answers
SOURCE: Problems with Onkyo DR-S2.2
I am trying to hook me DR-S2.2 receiver up with some existing speakers I found in my new house, but can't seem to get the center speaker to work. What mode does it have to be in so I can see if the center speaker works?
Posted on Jul 16, 2008
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
Why does the dr light keeps binking
Hello Gene Frank - Typically error code DR indicates an issue with the door switch and wiring not communicating correctly or closing properly. Try resetting the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective, contact a professional to move forward accurately.
Nov 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Sr576 standby light blinking
Most likely, you have DC Offset(a bad amplifier). The unit is shutting down to protect your speaker system, as well as protect the unit from any further damage. If you require more assistance, or would like to inquire about repairing your Onkyo, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jul 22, 2012 | Onkyo TX-SR576 7 Channels Receiver
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
Panasonic viera hd tv th 50pz80u
I have the same model and have the same problem. I have an Onkyo receiver that connections to the TV via HDMI cables. If I turn the TV power on first and then the receiver I don't get the blinks.
Dec 14, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Onkyo DR-S2-2
Have already posted this fix: Most common failure is the audio amp IC, reference # Q5001, which is an STK402-950 (Onkyo Pt. # 222123). Typically fails as a result of excessive volume levels or as a result of problems with the speakers or their wires. If you're technically inclined, the part can be had from various vendors & is fairly straightforward to replace once the complex disassembly required to access the PCB this IC resides on is accomplished, using standard soldering skills. A repair of this type by a reputable servicer may be more effective for non-technical folks, as typically can be accomplished for $200 or less, much less than replacement cost...
Nov 08, 2008 | Onkyo LS-V955 System
Onkyo TX-NR905 Protection Circuit Activated
The problem is not with the inputs. This unit is in protect because a problem has been detected in the output section. Try disconnecting the speaker wires and turning it on. If the unit remains on, there is a short in one of the speaker wires. If the unit still shuts down, there is an internal problem that will require repair. It sounds like this is a new piece. If so, it should be covered under warranty.
Keep us posted,
Dan
Jul 28, 2008 | Onkyo TX-NR905 Receiver
sounds like you have uneven flow of electricity. Try to plug the receiver in its own power socket
also make sure it has plenty of clearance for airflow b/c the receiver is shutting down to stop further damage of the receiver either b/c of heat or power surges.
good luck
smeags.
Jan 06, 2008 | Audio Players & Recorders
Onkyo DR-C500 won't recognize discs
Onkyo units as well as several other manufacturers have a common problem where the spindle motor gets intermittant or wont come up to speed.Its not hard to replace this motor, but could be a trick to adjust the platter height. Also the unit probably needs a servo alighnment as well. This unit could also have a simple problem as a dirty laser lens. You can try to use a disc lens cleaner to see if that helps. Good Luck
Jun 24, 2006 | Onkyo DR-C500 Multi-disc DVD Player
Onkyo LS-V955 System Logo
1,400 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
