Question about E-Machines eMachines Desktop PC
I haved a Emachine EL 1300G-01W that has crashed
I haved a Emachine EL 1300G-01W that has crashed for some unknown reason. It was hibernated and when I went back to use it, there was a black screen. When trying to restore using restore disk formulated before using the computer originally, it will not restore; saying only that there is a boot disk error. I went into the setup screen and it does not even show there being a hard drive. Need help trying to troubleshoot. I contacted tech support but they were useless in providing a solution, only to refer me to a webpage that did not address my problem. Can you help me?
My comuter screen says no signal when itis turned on and the screen is black?What can this be.
Posted on Jun 07, 2010
    Problem Solver:
  • 15 Answers
Power it down, pull the power lead out, remove the cover from the base and check that all the leads (to the hard drive and the motherboard) are seated correctly - by physically pushing them in. Then push and hold the power button on the front for 10 seconds. Then replace the cover and power lead and try starting it up.
Posted on Jun 05, 2010
Jumper settings emachine el1352g-01w
jumper on what, Hard drive? is it the only one? what type hard drive is it, how many pins?
May 30, 2014 | eMachines EL1352G-01w (884483537679) PC...
I cannot access the internet,i was using a wireless adapter that is slower than my computer,its the only way i get it.how can i work on high speed? i have a emachine el 1300g-01
Unplug or turn off your DSL/cable modem. Locate, on the back of your Linksys router, the small button that reads Reset. While pressing the Reset button, turn on/plug in router. Hold for 30 seconds. Wait for your Power, WLAN and Internet light to turn on. (On the router) Open your web browser to see if you have an internet connection. If you still don't have an internet connection you may need to restart your computer.
Mar 16, 2011 | Computers & Internet
Swap single core to dual core. and system shuts down for hardware problems. emachine el1300g-01w using windows 7 mother boards with am2 socktet. i installed the dual core processor and the pc ran good for...
I installed a dual core in my 1300g no problems. I we t against advice and tried a 65w tdp chip for a couple days and it ran a bit hot. A dual core am2 CPU for this machine must be 45w tdp or under. Research the dual core you tried. I'm betting it was too hot or needed to much power. Also the heatsink is crappy too. If you need a better one find a lga 775 heatsink with back plate. They it right in but check for height to fit in your case.
Feb 15, 2011 | AMD 4800+ Athlon 64 X2 Dual-Core Processor...
It said "hibernation locked" on
When they go into hibernation, they usually require your password to get back to normal operation. If it is forced to crash, damage to the system files will occur and that means starting in safe mode, if you can get to it. If you cannot get to the recovery partition I would use your recovery disks that you made when you first got the laptop and let it fix Windows for you automatically.
Dec 23, 2010 | Toshiba Satellite L505-S5966 Notebook
The computer is in a loop after a power failure. All wires are in the same place but it says NO SIGNAL. How can I returned back? The mouse is not working. The machine is EL 1300G-02W and has installed...
if the screen says no signal it is likely that the video card has sustained damage. If this is integrad=ted in the board (as on budget machines) it is time for a new PC
Jul 12, 2010 | E-Machines eMachines Desktop PC
EMachine model 1300G running XP. no audio
You betcha
this what you do, You go to your bios by F2 or whatever command that enters setup. You diasable the onboard sound card first. Go out and puchase a nice sound car around $40 bucks respectivly put it into a pci slot install your drivers and your good to go. remeber you speakers connect now to the back of the new sound card outputs not the one onboard.
Here is what i think what happend the back of the computer where the previous sound card was or still is those jacks may have died on you so you headphones that are plugged into the frount hack work and so will your speakers but i know its a hassel but a new sound card will take care of this iisue.
thanks i hope this information does help please do leave ratings and postive feedback for your free solution.
Apr 28, 2010 | E-Machines (308714) Motherboard
Hi my computor just recently went into hibernation mode and it won't turn to my original screen.I'll tell you what happend.It went to a black screen last night and i don't know if it crashed or not because...
when your computer boots up press F8 after the boot screen, its easy to miss the short period you can press this. This should prompt a screen which allows you to choose how to boot windows. Booting windows normally (without restoring hibernation state) or in your last good configuration that worked (it saves restore points pretty much every day your on it and will revert to that restore point) will be your best bets. Hope this helps, let me know if it gets tricky.
Apr 28, 2010 | Compaq Presario R3000Z Notebook
I reformated my computer and had it on hibernate and went to sleep.I woke up and now the screen on my desktop pc just flashes about every 3-4 seconds.the screen stays black the flashes with white streaks...
Hi there
i read your report. OK go to your power options and turn off your hibernate and restart your computer.allot of times after you have reformatted your hard driver. the hibernation doesn't work correctly. Try this tip and let me know how it goes. Thank you for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | HP Pavilion F1703 17" LCD Monitor
Computer stuck on black screen from crashing
Make sure that your hard drive is set as first boot device and disconnect all the USB devices from the system and than try to boot.
Apr 21, 2009 | Computers & Internet
E-Machines eMachines Desktop PC Logo
269 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
