The fan inside the house part of the ac is not going round but it makes a sound as though it wants to. The outside unit is working fine.
    Sergeant:
  • 338 Answers
It may be the start capacitor on the fan motor. or the motor could be weak. But I would bet its the capacitor.
Posted on Jun 28, 2010
My outside unit is making a loud weird noise but the inside unit is working completley fine it is 7yrs old now
the outside unit is where it all happens. That is where the compressor is and its cooling fan. The inside unit is just an evaporator, a bit like a car radiator and a fan. The inside unit is protected by the room, the outside unit is in the rain, snow and wind.
You need an AC engineer.
Feb 01, 2016 | Heating & Cooling
Goodman troubleshooting
which fan inside or outside hum sounds like compressor is running if outside fan try moving fan blade probably find it dragging or cant move bad motor
Sep 08, 2014 | Heating & Cooling
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
I have a goodman gsc13 ac unit about 4 year old. When the temp gets around 90 or above outside the fan on the unit starts but the compressor does not. I had service check it out but that day they were...
It sounds like the unit may be over charged. Make sure the outside coils are clean and you have plenty of airflow coming out of the top of the outside unit. What could be happening is, when the temps get higher outside, so do the pressures in the system. The compressor has a thermal overload protection that will kick the compressor off if it gets to hot, which if the compressor is over charged, it will work twice as hard, over heat and shut off. You would need a technician to come out and get the refrigerant charge back to normal. Another thing that could be happening is a weak or faulty capacitor, which is a small round or oval metal object, found in the electrical compartment on the unit. This are fairly simple to change out if your comfortable with electric. I've also had to put what's called a hard start kit on compressors with the same problem, new and old. The hard start basically gives it that extra boost of power to get it up and going. I would start with the refrigerant charge and go from there. The electrical "humming" sound that you hear unless you turn the breaker to the furnace off, is the contactor on the outside unit having a call for cooling. The 24 volts come from the furnace, to the outside unit, and pulls the contactor in to power the unit with the 220 volts supplied. It is normal and you don't have to worry about that at all. I hope some of this helps and good luck!
Jul 05, 2011 | Heating & Cooling
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Ac inside unit problem
sounds like you have a bad evap fan motor, fan relay, or capapcitor. It's also possible your unit is froze up.
Apr 25, 2009 | Heating & Cooling
Inside fan runs constantly on my AC
Raise your thermosat to about 78. Also check to make sure the thermostat is set to auto and not on...
Jun 12, 2008 | Whirlwind FH-778 Air Conditioner
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
