Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Colors seperate picture colors seperate on screen with distinct 2 inch seperations in color. Is this problem fixable.
  • 10,594 Answers
Yes, this problem is fixable.
Replace convergence out chips on D board of tv to fix the color separation issue.
Posted on Jun 05, 2010
Testimonial: "Thanks, I will try, I am thankful for your help"
Have a sony 46 inch rear projection model #kp 46wt510! Purchased it new in 2004! Have nothing but great things to say about picture untill today! I have a color seperation with red, whatever line or...
This is problem of convergence output chips failure and it is fixable.
Replacement of convergence output chips on D board will solve tv problem, local tv repairman will do this job because convergence output chips replacement requires soldering work on circuit board.
Thanks.
Jan 01, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Colors are seperated throughout screen. started in corners over a period of several weeks, and now colors are seperated by about 2 inches
u have bad convergence ic , for this repair i would recomend to hire a tv repair tech , this job require alot of soldering and aligments , $250 - 350
Nov 03, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Picture colors are seperated on my tv. the sound
Hi i did not want go to far whit this//
usely you will have to replace the convergence module there are 2 stk ic on it,and then use the magic focus button on the front panel/ if it not fix back your color alignement you will have to do manually whit the remote control.
but that needs some experience to do so...
hope that help ,its give a idea
have a nice day
Mar 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Objects are shadowed on screen and color seems to be seperating
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 30, 2009 | Toshiba TW65H80 TV
Color seperation but still have a picture
Problem with tv is convergence-unit is made by samsung.You can eithor replace the convergence board or trouble-shoot it yourself.
gonna need to replace both ics STK392-040-then check all the 3.9 ohm resistors
Sep 10, 2009 | Akai PT5598HD 55" Rear Projection...
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Colors seperating.
What make and model TV do you have? Each one is different to gain service menu.
Jan 14, 2008 | Televison & Video
Colors have seperated on top of screen
convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Televison & Video
32 inch sony trintron tv red blue green
Switch OFF TV. Open rear Cover. Switch ON the TV. Now, very carefully, (There are very High and Dangerous voltages inside, also, use a mirror to see the screen) adjust a red colored box called "H.STAT" which controls the Horizontal Convergence of the CPT. Should solve your problem. Check some Vertical portion of a object (Text in some Video Title, wall of a building, etc, ) as a reference.
Sep 04, 2006 | Sony FD Trinitron KV-28FQ75 28" TV
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
692 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
