When i tried formatting thinking it to be a virus problem, after copying some windows files, it stops and error msg displays ' could not copy files, it its for the first time, restart or check for any new installed hardware or virus. run chkdsk/f and so on. cant continue then. please support
  • 19,396 Answers
Hi.
That means that either the media where you want to copy the files is faulty or write-protected(eg. when using an USB stick), or that one of the files is corrupted.
Try copying different files one by one. Let me know if the problem happens with all files.
Also let me know from where to where you are copying the files (eg.from USB stick onto My documents on C: drive).
Thanks.
Posted on Jun 05, 2010
  • noklam Jun 05, 2010
    no sir actually laptop failed to boot. thats why i tried booting with the bootable xp cd. it even did not take that. so what should i do now. tried formatting, but stops in the middle. it says cant copy files.
  • Ginko
    Ginko Jun 05, 2010
    Re:"no sir actually laptop failed to boot. thats why i tried booting with the bootable xp cd. it even did not take that. so what should i do now. tried formatting, but stops in the middle."
    If you had Vista installed in your laptop, that may be the reason. XP install disk and XP boot CD often do not recognize SATA hard drives. Try changing BIOS settings from SATA to IDE compatible drive controller before installing XP. See:Windows XP setup ...
After formating partition C i wanted to install a fresh copy of windows XP but after copying 9% of files into the partition, a msg appeard that some file cant b copied, and also i tried with 3 other w
This usually means that you have HDD bad sector or some kind of HDD read/write error.Boot up in DOS mode and use HDD Regenerator to check and repair your hard disk drive.This can be easily done with Hiren's Boot CD. You can download it from here. After downloading, burn ISO on a disk and try booting from CD-Drive.
Nov 16, 2011 | Microsoft Windows XP Professional
My pc do not allow me to copy files and folder from one place to another and display error msg "Internal error 00000005" or "file integrity voilated".
It is an virus indication if you are using antivirus scan your computer it fix the problem automaticly and if no, so restore the system
Aug 02, 2011 | Computers & Internet
NTLDR IS MISSING for HP 530
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
    Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Jul 28, 2009 | Computers & Internet
' file integrity violated' error message.. copy problem
A message display as file integrity violated display when i try to copy or move the file
Jul 23, 2009 | SanDisk CompactFlash PCMCIA Adapter
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Files in my kingston pendrive does not open up
Hi manoj_clc,
The "other PC" needs to have the same application installed that created the files. It sounds likely that is the problem for the other PC. If the files are failing to open using the PC that originally copied the files, then try formatting the USB drive (formatting deletes all data). Before you copy the file again, make sure the same file opens from your computer prior to copying it. Now copy the file to it the USB drive again.
Kingston Tech Support
May 03, 2009 | Kingston 4GB Secure Digital High Capacity...
Windows was unable to complete the format
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hard disk stops copying
sir,
first you scan pendrive with anti virus Soft ware why mens i think virus probalm your pendrive ok check pendrive witch company pendrive sir give me details full ok have a nice day by sir
Mar 14, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
