Question about Applied Microphone Technology 1964 Ford Galaxie 500 by Model King
1964 Ford Galaxie 500 - 289; 2 barrel carb; If I pour a little gas in the carb, the car starts for a few seconds, but not getting gas after that. Took the fuel line loose and blew air through the carb, and backward into the tank. Line seems clear. Any other suggestions?
I have a john deere stx46 that will crank but not start. Gas is getting to the carb but nothing seems be be coming out the other side of the carb. Could the carb be clogged?
pour a little bit of gas in the carburetor and try it. if it starts for a few seconds it may be clogged and need to be cleaned. change the spark plug first. and try if it wont start then try the carburetor.
Jun 09, 2016 | John Deere Garden
Brake pull when applyed
go back to the people that did that work and holler loudly it was not fixya was it ?
Feb 12, 2015 | Galaxie Conquest 1964 Ford Galaxie 500...
John deere lawn tractor rx 95
carburetor needs cleaning. sounds like the Needle valve is not doing its job
Apr 22, 2014 | Garden
Gas pouring into carb
carb float problem
Apr 22, 2014 | John Deere Garden
1979 FoMoCo 4 Barrel carb. Getting good fuel flow and pressure to the carb. Engine will start and run for a few seconds then run out of fuel. New fuel pump has been installed. Can blow through gas...
is the needle opeoning on the float in the carb? The fuel bowl should be about half full all the time. As fuel pressure flows into the needle & seat, it fills the fuel bowl until the float pushes the needle into the eat. Sometimes the rubber tipped needle can stick in the seat.
Holley carb? Autolite carb? Holley 4160?
Sep 09, 2011 | Ford Econoline Cars & Trucks
Performed single barrel carb rebuild on 63 ford and ran fine but after few days fuel started pouring out the vent rod...help plse. Thx Bob
one of two things has happend either there is trash under the needle and seat or the float has sunk...good luck
Jul 16, 2011 | Ford F Cars & Trucks
Carb gas pouring out of hole on top front of carb
Sounds like the float has absorbed gasoline and can't ftoat anymore. This causes the fuel to not be shut off when float bowl is full causing the carb to flood. You will have to buy a carb kit and a float and rebuild the carb. Hope this helps.
Feb 15, 2009 | 1966 Ford Mustang
Applied Microphone Technology 1964 Ford Galaxie 500 by Model King Logo
159 people viewed this question
Top Applied Microphone Technology Toys Experts
ray gallant
Are you an Applied Microphone Technology Toy Expert? Answer questions, earn points and help others
