Question about Bosch Dishwashers
Hi. The water from the last wash has no drained out and the two lights - Check water and Rinse aid - are lit.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check that the disposer unit (if connected with the dishwasher drain hose) is not knocked out, hoses, drain pump and filter are not clogged or kinked. The drain hose and pump aren’t working properly or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and it is cleaned then it is an issue with the drain pump. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 05, 2010
We have a Siemens dishwasherSN66T091GB. The unit is not showing a fault code but the 'tap' light and 'rinse aid' lights are flashing continuously.
Tap symbol indicates a water problem.
Check that the water supply to the dishwasher has been turned on.
Check that the water supply hose hasn't bent or kinked.
Check the water supply first, see what you find.
Rinse Aid symbol light indicates low on rinse additive.
Hope this helps?
Oct 16, 2016 | Siemens Dishwashers
My wf310 1100 spin will not do a high speed spin
hi, there may be not enough water draining out on the last cycle before it spins so i'd give the pump a good luck over also check the filter if it has 1, and check the drain hose. the other fault could be the module control board this controls the motor speed hope it helps
regards
shaun
Nov 27, 2011 | Washing Machines
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
May 19, 2010 | Dishwashers
Maytag DWU8330AAX: glasses, plates, utensils,
The rinse cycle is the same as the wash except the wash uses detergent and the rinse uses rinse aid.
The rinse cycle will dispense rinse aid if you have filled the dispenser. Check this first, that would be the most likely cause. Also in the spring as the water table table in most cities begins to rise the water quality goes down, extra calcium in the water can cause this problem.
Here is a link to help understand that. Let me know if you have questions.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
May 02, 2010 | Dishwashers
I want to change my rinse aid product
run it through a couple of empty washes or use it just to wash dishes without rinse aid. this should allow you to add rinse aid into the container after each wash there after just add more rinseaid. it could take a while to get full rinseaid coming out but eventually there should be only rinseaid in the container.
Apr 10, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Feb 21, 2008 | Dishwashers
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
