Question about Sharp Microwave Ovens
Interior finish of microwave wearing off
We have a large Sharp microwave. There are small areas in the corners and bottom ''seams'' inside the oven, where the finish is actually worn/chipped off. And it is discolored in other areas...turning gray. There are also gray drip-like streaks coming down from the area where the interior ceiling meets the interior walls...and these streaks do not come off with cleaning.
Is it safe to continue using this microwave?
SolutionGuy
  • 331 Answers
SOURCE: Replacing the interior lamp inside the microwave on the top.
Yes, Bobby, it can be done. Before you begin, though, go to Home Depot and look in the tool department. There, ask for a "Husky Pro #66604". It's a 1/4" and 5/16" drive 90 degree ratchet that's about 4 inches long. While you're there, pick up a #2 1/4" drive phillips screwdriver bit. You'll use both of these to do the light. Both for about $12. UNPLUG YOUR MICROWAVE! Stand on a small ladder in front of the Microwave (MW), remove the 2 screws that hold the vent louver in place and remove the louver. You'll now see a black plastic grill (just above the door handle)remove the 2 screws with your new tools and remove the grill and the metal box that covers the relay. Now remove the 2 screws holding the horizontal metal panel that the box was sitting on. Now gently lift that panel up, (don't try to remove it) and you'll see the lamp. It's the one with 2 white wires going to it and a shiny metal cover over it. Place your index finger on the back of the cover of the lamp and gently pull toward you and lift at the same time. This will release the catch and allow you to pull it all the way out to get to the lamp. There ya go! Simple!
Posted on Jul 30, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Oven Interior Paint
Yes, but if this is not fixed, it may flake off and get in your food, or allow grease or food particles to build up on the surface.
The loose paint should really be sanded off, at least.
Then when it's clean and dry, you can apply a little high-temperature appliance paint, available from department stores, home improvement centers, and appliance parts stores.
Posted on Oct 12, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: interior cardboard/foil piece fell off revealing small chamber inside oven--still safe?
This is the mica or plastic waveguide cover. It protects the waveguide and magnetron form grease and food particles.
Assuming you're going to scrap the unit, carefully clean the area around the outside of opening (watch for sharp edges) with a lightly damp soft cloth.
Then use alcohol or a hair dryer, etc. to be sure the area is dry.
Then you can use a couple of strips of clear packing tape to cover the opening and trim it with a razor blade so only about 1/4" or so extends out from the opening.
Note that I only recommend this procedure on an oven that is going to be scrapped. If the oven will see continued use, a new waveguide cover should be purchased.
Posted on Oct 24, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, you can have rust and arcing, which can be messy.
Posted on Nov 23, 2008
rickzilla
  • 706 Answers
SOURCE: Is my dented microwave safe to use?
Hello carillon553,
If you haven't compromised the door opening or inner compartment, then it is more than likely OK to use. The magnetron ( which generated the microwave energy ) has a waveguide that focuses that energu into the cooking compartment and a small dent to the cabinet normally has no impact on its safety.. Hope that helps..
If you are overly concerned with that, then you would need a technician that has an RF Power Meter to check it.. If it were me, and the dent was small.. I would just use it...
Regards,
Rick
Posted on Dec 13, 2008
Sharp R408LS keeps sparking after minimal use. This is our 3rd one. This is mounted on an inside cabintet.
The magnetron is arcing in the interior and will eventually burn out. Check the inside for bare metal or food particals, if okay! the magnetron is breaking down and will eventually go.
Apr 21, 2012 | Sharp R408LS Stainless Steel 1100 Watts...
There is a burn mark in the back corner. We sometimes see electrical 'arcs' in that area when its running.
A convection microwave is more forgiving with small bits of metal than a regular microwave so the small chip won't make a difference. What you are seeing is the initial stages of magnetron failure which means that soon you will be in the market for a new microwave.
Sorry the info isn't of a happier nature.
Mar 05, 2012 | Sharp KB-6002LS 1000 Watts Convection /...
The enamel is wearing off where the back side meets the base on the inside of the oven. No sparks are flying but is this repairable? Emerson MW8775W Microwave Oven
Small areas inside the cavity can be repaired. The bare spot must be very smooth. You can sand it down if needed and then repaint. There is a m/w cavity paint sold in a spray can, but I've had really good luck using regular appliance touchup paint. Just be sure the spot is very smooth when you finish. Use several thin layers of paint instead of one thick layer and you should be ok.
Dec 28, 2010 | Emerson MW8775W Microwave Oven
Paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Jun 20, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
How do I clean the inside of the microwave? It is
DO NOT use SOS pads! They are made of STEEL WOOL and will remove the protective finish inside the oven cavity. Without the protective coating, the microwave can arc internally and ruin the magnetron. Use the green scrub pads you find in the dish detergent section of your local grocery store. They are considered non-abrasive. Use the green scrub pads along with a non-abrasive cleaner such as Soft-Scrub or 409. Wipe clean with a fresh water and dry with a clean cloth.
Jan 30, 2010 | Sharp R-1505 Microwave Oven
Cracked seam inside Microwave
It will have to be sanded smooth and clean and dried thoroughly.
Then if the steel seam is actually cracked / separated, then you can apply a very thin bead of steel-based epoxy "J-B WELD". When it dries thoroughly, you can sand it smooth.
If it's just the paint that's cracked, it will have to be sanded smooth and clean and dried thoroughly.
Jun 27, 2009 | General Electric Microwave Oven
Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Mar 25, 2009 | Sharp R-820B Convection/Microwave Oven
Microwave: Box seam is separated - Is this dangerous?
Better safe than sorry.
Jan 29, 2009 | Sharp R-1480 Microwave Oven
Interior cardboard/foil piece fell off revealing small chamber inside oven--still safe?
Oct 22, 2008 | Microwave Ovens
Maytag MMV1153BAW interior access panel
This is the stirrer cover. It is important. It is to keep food particles and grease out of the stirrer and waveguide area.
If grease or food particles build up, they can arc, which will cause burn damage to the cover, stirrer, chassis, and/or magnetron.
If you have any arcing, you should remove it for cleaning. Be careful of sharp edges.
The stirrer's job is to stir the microwaves to ensure even heating, even when a turntable is not present or not used.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 05, 2008 | Sharp R-530BS Microwave Oven
Microwave Ovens Logo
60 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ed Mac
Jim Thurston
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
