Question about Traeger Industries BBQ100 All-in-One Grill / Smoker
Looking for older traeger bbq100 wiring diagram. i had a stuck auger (expanded pellets), cleared it and cleaned everything up. hooked everything back up and now it comes on, the auger runs for a bit (minute?) and then stops. if i turn it on and off it starts again, wondering if i plugged something back in wrong? thanks
  • 332 Answers
SOURCE: When I turn my traeger on, the auger turns for
Call Traeger direct. I had the same problem with mine and the sent me a new control unit. Install time 15 minutes fixed the problem
Posted on Mar 07, 2010
Testimonial: "thanks for you help!"
  • 332 Answers
SOURCE: The pellet auger on my traeger doesn't feed pellets
Call Treager direct
They have a great customer service dept and if you have an issue with a motor or control board they are really good about sending replacements
800-372-3437
If this helps please leave a comment
Posted on Mar 30, 2010
  • 34 Answers
SOURCE: How to charge an auger on traeger grill
Turn the control on high and wait about three minutes. Shut contol off and restart in about 1 minute, This should have enough pellets in the auger to start before the hot rod shuts off. You can also put a hand full of pellets in the burn pot and usually bu the time these pellets are burned out the others are there. A couple of cycles usually will start them.
Posted on Apr 17, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Traeger BBQ070, purchased 4 months ago.The auger
Sorry to read about your problem, I hope this helps you out.
you have a defective auger, you are under warranty. so dont try to make repairs contact Traeger
http://www.traegergrills.com/support/
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
SOURCE: My Traeger (BBQ070) will feed the pellets, but there is no ignition to burn the pellets.
Be sure check the fuse behind the control board when pellets auger in but do not ignite.
Posted on Feb 15, 2012
Breaking up solid pettet in auger
Traeger has an FAQ related to this on their website at http://www.traegergrills.com/. Look for it under" why are there no pellets in the firepot?" You may have to remove the augur but Traeger explains how to do it in this FAQ.
Jul 06, 2014 | Traeger Industries BBQ070 All-in-One Grill...
My trager grill is smoking a lot in the pellet hopper
That could mean that pellets in the augur have caught fire and it can work its way back to the hopper. Then you really have a problem. Are you sure the fan is running?
You should be able to hear it. The fan helps keep the heat from working its way into the augur. If it's not running, you should also be having trouble controlling the temperature.
Traeger has specific instructions on its website for testing various components including the fan and customer support can assist you with this problem.
Here's a link to the Traeger website: http://www.traegergrills.com/. I'd suggest you get in touch with them ASAP because you definitely don't want to deal with burning pellets in the hopper.
Jul 05, 2014 | Traeger Industries BBQ100 All-in-One Grill...
Traeger grill not smoking
This is a common complaint about Traeger grills. Some people have resolved it with smoke pipes which contain pellets that smolder during the cooking process.
Others use different pellets than Traeger pellets but they void their warranty when they do. For me, Traeger pellets seem to put out enough smoke at the low temperatures I use (less than 200 degrees) but if I get above 200, the smoke goes sway.
When I cook pork shoulders, I try to keep the temperature at 180. In ideal conditions the Traeger will fluctuate between 160 and 200, averaging 180. If I can maintain this low-slow cooking temp-speed, I get a good smoke ring and decent smoke flavor.
If I get above 200, I lose much of the flavor but usually have a smoke ring though not as intense as at the lower temps. There are lots of conversations about this on blogs at the Traeger website and at the Pelletheads website.
Jun 14, 2014 | Traeger Industries BBQ100 All-in-One Grill...
On smoke setting my temp goes up over 300 degrees
Traeger suggests realignment of the augur for grills that are not getting hot enough. I wonder if this might be the same solution for grills that are getting too hot.
Here's their solution which I copied from the Traeger website at http://www.traegergrills.com/.
I've been noticing that my grill temperature keeps dropping lower. What is the problem?
You need to "true" your auger. To do this:
  1. Run the unit out of pellets.
  2. Remove the allen screw and nut out of the auger and motor shaft.
  3. Try spinning the auger shaft over the motor shaft. The auger shaft should spin freely over the motor shaft without binding.
  4. If the auger binds, loosen the 7/16th inch bolts on the motor bracket and move bracket until you can rotate the auger shaft over the motor shaft. Then re-tighten 7/16th inch bolts. Make sure auger shaft still rotates over motor shaft, or repeat step 4 again until it does.
  5. Reattach auger and motor shafts using the screw and nut which you removed in step 2.
You might want to contact Traeger at their website to verify that this is a solution for overheating. In the above case, the improperly aligned augur was not dropping enough pellets in the firepot. In your case, it sounds like it may be dropping too many. This sounds like a routine maintenance thing that ought to be done periodically anyway.
May 12, 2014 | Traeger Industries Grilling
I'm getting an "Err" message on my digital temperature reading. The grill starts up but then shuts down when the "Err" message comes up.
Remove your grill, inner shield and outer dip plate from the Traeger. Start the Traeger in smoke mode. Observe to see if the blower fan is working. Is the auger turning? Are the pellets dry? Condensation can make the pellets swell and cause plug ups.
Aug 13, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Old BBQ100 that needs r4built
Here's the company contact info so you can get the parts directly.
To order parts directly from the factory:
PARTS DEPARTMENT
TRAEGER WOOD PELLET GRILLS LLC.
PO BOX 829 ,Mt. Angel, OR. 97362
(503) 845-9234 1-800-872-3437
Fax: (503) 845-6366
Email: traeger@traegergrills.com
Website: www.traegergrills.com
May 15, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Apr 16, 2010 | Traeger Industries BBQ100 All-in-One Grill...
The pellet auger on my traeger doesn't feed pellets. It is not stuck as I can turn it with my fingers. Any ideas? Are there any resets? Everything else seems to be working OK.
Call Treager direct
800-372-3437
Mar 28, 2010 | Grilling
Traeger Industries BBQ100 All-in-One Grill / Smoker Logo
416 people viewed this question
Top Traeger Industries Grilling Experts
Gary Kenady
Gary Kenady
Craig Butler
Craig Butler
Paul Carew
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
