Question about Dishwashers
Hello! My 3 yr old Bosch dishwasher (I think it is a SHE 43) is doing two things: 1) leaving a serious white film on dishes and glasses 2) leaving grit inside glasses on the top rack (always on glasses placed on the far back right of the top rack) I've tried cleaning the machine with hot washes with no dishes, vinegar only, but no luck. Any thoughts? Many thanks for your help!
  • jemcculloch Jun 05, 2010
    To clarify a few points - we are not using stale or clumping powder soap, and the dishes are not overloaded or improperly loaded.
    The machine appears to be draining properly (no water left in the tub when done). We have cleaned the little cylindral filter and the larger grate where the bottom spray arm attaches on the floor of the machine.
    I've checked both spray arms and there are no obvious cracks or splits.
    Thanks in advance for your help!
  • 10,865 Answers
Hello. Since you have already cleansed the interior of your dishwasher, we must conclude that the problem is with the water itself. If you do not have a filter on your water, you may want to consider installing a dirt/rust filter, at least on the hot line that feeds your dishwasher. Also, you should consider draining and rinsing out your hot water tank as it may have accumulated gunk in the bottom of it. Joe
Posted on Jun 05, 2010
  • jemcculloch Jun 06, 2010
    Interesting thought. Here's what I am wondering - what about the grit in the glasses - only on the top right side? If it was the water, wouldn't that be on all the dishes?
  • jemcculloch Jun 07, 2010
    So - other thoughts? I flushed the hot water tank (wasn't terribly gunky - got some rusty water and some mineral deposits, but nothing dramatic) then ran a hot load with vinegar poured in. Then ran the dishes - still covered in a chalky white residue, plus grit left in the glasswear placed in the top rear right corner. I'm using the same detergent I've always used (now called finish, was electrosol) plus lots of rinse agent (we live in a hard water area).
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check that the Powder soap is stored in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded. Dishwasher will fill with water up to and around the heating element. If water is more below the heating element, there is a low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure. For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. As the water is not draining please check that the drain hoses and drain pump are not clogged or kinked. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jun 05, 2010
    First of all please check the Water temperature by using a
    thermometer inside the dishwasher to measure the water temp. It should be as
    close to 125 degree F to 140 degree F as possible. Now try using the
    temperature boost feature if your dishwasher is equipped with this cycle
    feature and check if this will help your wash ability issues.
Glasses and dishes have a gritty residue...dishwasher is just a year old and this problem has been happening for as long as we've had it. What should i do...This is gross
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Jun 02, 2011 | Bosch SHU9915UC Dishwasher
Bosch Dishwasher leaves a sandy filmy residue on our glasses. Cascade Dishwasher soap is always used and dishwasher cleaner used about every 5 weeks. Dishwasher is run thru a complete cycle every 2 days. ...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Feb 06, 2011 | Bosch SHX55M02UC Built-in Dishwasher
I think the rinse cycle is not working on my Bosh dishwasher. It is leaving a soap residue on the dishes.
heatman101
Jan 14, 2011 | Bosch SHU9915UC Dishwasher
My GE dishwasher is 2 months old. The dishes are coming out with a film on them and the stainless steel inside has a white residue on it. I am using the recommended cascade products.
Do you know if you have hard water. It sounds like a hard water film. 1) purchase several applications of dishwasher cleaner from your local grocery store. Use them all back to back. 2) The only detergent I have found effective with hard water is called Somat. You may try your local appliance parts retailer for this. 3) The best solution is a water softener for your house.
To confirm if this is hard water, soak an affected glass or dish in the sink with 1/2 white vinegar and 1/2 water for a couple minutes. Then simply dry, if the film is gone its hard water.
Jan 14, 2011 | GE Dishwashers
My Jenn- Air dishwasher (2 years old) used to clean great but now it is leaving a white film on the dishes and there is often residue left in the glasses as if it is rinsing with the dirty water. I can't...
heatman101
Nov 20, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
#1 Dishes and glasses are not clean. Glasses come out with *** film. #2 Cascade gel soap residue in cup dispenser and on dishes close to it. #3 Not drying glassware in upper rack. #4 Black ***...
heatman101
Jul 14, 2010 | Kenmore 24 in. 17602 / 17604 / 17609...
Hello, Recently my dishwasher has been leaving particles of food residue in glasses or other glass items. This is a particular problem when using the top rack, but the problem sometimes is also on the...
heatman101
Jul 05, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
White crusty film residue on plates and glasses after washing,
heatman101
Apr 27, 2010 | Bosch SHU5315UC Dishwasher
Making noise and leaving white film on dishes
the white film is due to hard water. go to www.dishwasherfilter.com and get the new difi filter. it will solve your problem imediately and extend the life of your dishwasher. the product is amazing and guaranteed to work. very affordable
Mar 29, 2010 | GE Nautilus 24" Built-in Dishwasher
Residue on dishes/glasses - Hard water? How to clean?
heatman101
Mar 01, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
