Question about Omega There are seven (7) different output vol...
Laptop will power off without notice
Hello, I wonder if any one else has had the problem of their laptop powering off without notice. It just shuts right off and there is no pattern to the behaviour.
It does happen more frequently when I am watching a video (eg: a Madmen tv episode from CTV.ca) But it will occur just even doing e.mails.
I am running Omega with Windows XP Home. It has 120GB Hard drive, 1024 Mb RAM and Intel Core Duo Mobile Processor 1.6GHz. 2Mb cache.
Any suggestions as to what is causing this would be appreciated.
Thanks
  • 540 Answers
The problem you are facing is due to over heating please take the laptop to any nearby computer store and clean all the exhaust of the laptop.
Posted on Jun 05, 2010
Why is my computer always going off without me shutting down?
Could be malware or corrupt files or a bad connection on battery or power supply.
Aug 26, 2015 | Sony Computers & Internet
Laptop power light comes on , fan starts then laptop shuts off
Laptops (and PCs) have sensors to kill the power when overheating takes place, particularly the CPU. You should take it to a local repair shop and let them look at it for you
Oct 03, 2017 | Acer Genuine Aspire 5250 5333 5733 5733z...
When I go to start menu to shut down and press shut down it will just reboot and will ot shut down
Step 1:
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Feb 20, 2013 | Acer TravelMate 2300 Notebook
Sudden Shutdown due to Overheating
either your power adapter os faulty or the cooling fan inside the laptop had failed forcing the laptop to shut down as safety precaution.
Aug 29, 2012 | Dell Inspiron 14 N4010 Laptop 4g 500gb...
New battery in Acer laptop shuts down computer at 44% power ?!?
In the power options at the control panel you can set the battery options there to shut down at a lower percentage. Also within the software for your battery as well. At the task menu lower right hand corner tick the battery settings. John
Apr 09, 2012 | Computers & Internet
I undocked my compaq 6320 laptop - just after accidently hitting the dock- power button (before hitting the eject button). I ejected the computer but noticed it began to start-up but shut down because my...
Try removing the laptop from the doc, pulling out the battery, hold the power button down for 10-20 seconds, and re-install the battery.
This should drain out the laptop and it should boot up properly without the dock.
May 27, 2011 | Computers & Internet
Unexpected shut down of my HP Compaq I was trying to close the windows I was working witt when all of a sudden without notice my laptop shuts down. I tried to restart it but it would not. I took off the...
Compaq's are famous for over-heating, if you didn't have a cooling pad under the laptop it may have burned up some components, or it could just need time for the components to cool.
Jan 07, 2011 | Computers & Internet
Turning off
Perform power drain ( remove all accesories including the battery and the power adapter) press the power button for 1 minute.
Connect the power adapter only then turn on the computer - try using for more than 1 hour. If the computer does not shut down then the issue is the battery.
Run anti virus software.
If problem still persist it is a posible hardware issue. If you are still in warranty you can call sony and they can help you fix the issue for free.
Mar 27, 2010 | Sony VAIO Notebook
Acer Ferrari shuts down
This sounds like a shorted power supply or even worse the motherboard, or processor. There might be parts that are still damp let it dry out longer you could try a hair dryer on a low setting before taking it to a repair shop.
Aug 14, 2009 | Computers & Internet
Laptop will not power on at all.
Don't know what you have for a laptop, so will have to give you a generic process, here. Power down. Remove hard drive, remove cd reader and/or floppy drive. Remove memory cards. Replace only 1 memory card in the main slot (probably marked as slot 1). Try to power it back up and let us know what happens.
Thanks!
Ron-
Nov 02, 2007 | Computers & Internet
Omega There are seven (7) different output vol... Logo
52 people viewed this question
Top Omega Computers & Internet Experts
David Payne
David Payne
Are you an Omega Computer and Internet Expert? Answer questions, earn points and help others
