Question about RTO Atwood Water Heater - 6 Gal LP
Bypass check valve I need a prplacement part for the bypass check valve in my Atwood combo RV water heater
  • RTO Master
  • 6,674 Answers
Any RV sales and service place should have them.
Posted on Jun 08, 2010
Low or No Flow - Atwood 10 Gallon Elec, Gas, Heat Exchanger Type RV Water Heater
if good pressure on cold side check heater bypass maybe valve open partial or kinked hose
May 28, 2018 | Water Water Heaters
My Atwood RV Water heater does not allow water to pass through. It goes in the bottom but does not come out of the top. No clogs are apparent and the plumbing all passes water. I removed the bypass valve...
The fitting at the top of tank where line connects is usually a check valve, Good chance the check valve has blown apart inside and plunger is blocking flow through it. Either get yourself another or even use a short 1/2" NPT plastic or galvanized pipe nipple to replace it and you should be good.
Jul 14, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I just bought a Jayco trailer with an Atwood 6 gallon water heater which works on both electric and gas. I was able to locate the bypass valve and made sure hot water was in the tank, however I only get...
Check your by-pass again. Cold water enters bottom fitting/line, and hot comes out the top fitting/line. Any valve in between should be closed, and any valve going in at bottom should be open, as well as open at top. There are a few different by-pass set-ups, so without knowing which one you have, this should guide you somewhat.
If you can describe what you see there, I can probably guide you through it.
May 07, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
When i turn the hot water on fast i here a click ( comming from the vacinity of the water heater) and the water stops. This is at all water faucets. Sounds like a check valve? there is a bypass valve at...
The hot side (top line) should have a check valve between tank and water line. I'd replace it. Be sure you install new one the right way. Stem, spring etc should be facing in tank.
Jul 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a 1994 pop up with an Atwood water heater. I hear the water heater turn on when plugged in but no hot water.
Have you checked your by-pass at rear of water heater to make sure it's in proper position? If it's still in bypass, you will only get cold water from either tap. Cold water goes in bottom, and hot comes out top. Any valves in between those 2 lines need to be off. Let me know what you find, as they use a few different ways to do the by-pass.
Apr 26, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood. Will not light. Red light comes on and stays on.
A GOOD RV DEALER SUCH AS WHERE I WORK HAVE A BOARD TESTER AND CHECK IT FOR FREE. A DEALER NEAR YOU SHOULD BE ABLE TO DO IT FOR YOU AS WELL. THE SENSORS ARE THE ECO AND T-STAT. NO, THEY CAN'T BE BYPASSED. THE ECO AND T-STAT WORK IN CONJUNCTION BY REGULATING THE WATER TEMP AND PROVIDING POWER TO THE CIRCUIT. THEY ACT AS SAFETY DEVICES.
Sep 24, 2009 | RTO Atwood Water Heater - 6 Gal LP
My rv water heater ignites, I have a steady flow of water in the sinks from the hot water spicket, but no hot water. The bypass valve is positioned paralllel to the cold water valve. I am not sure of the...
If your lighting and not getting hot water then you have a valve closed or your by pass is in the wrong position, if it is burning on gas it will heat water
Sep 06, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
RV water heater problem: my water heater ignities, when I turn on the hot water faucet there is a steady flow of water but no hot water. The bypass valve is parallel with the cold water line. I can only...
The first question is this
From the outside of your RV is the water heater square or is it longer than it is tall?
If it is square it is a Suburban
If it is longer than it is tall then it is an Atwood
Forest River mostly uses Suburban
How long do you let the unit burn/run before you try the hot water? From a cold start it will take - depending on the outdoor temp. & the gallon size of your water heater, 15 to 30 minutes for the water to get hot.
If you have waited this long then I would suspect the bypass valve is in the wrong position
Hot water does not come out
I pulled the water heater out of the rv and found the one way value broken and cloged.replaced with new one $9.12 and put back together.works great.
Mar 27, 2009 | Water Heaters
RTO Atwood Water Heater - 6 Gal LP Logo
443 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
