Viewsonic VX2255wm-3 monitor stuck in analogue mode. For some reason it won't switch back to digital. This reduces sharpnes, makes colours seem washed-out, and and makes some games like Dawn of War 2 unplayable. I've had this problem a lot of times since I got this monitor, and usually it just fixes itself after a while. Now It's happened again, and I don't feel like waiting it out. Any ides on how to fix this?
furion187
  • 54 Answers
SOURCE: viewsonic monitor seems to be stuck in sleep mode
Sound's to me more like a Video card issue, try the monitor in another computer if you are able 2 , otherwise please make sure video card is in tight and secure , not 2 sure what you mean by sleep mode, are you using windows vista? or xp? you may need to change some settings on your operating system , when you turn on computer do you see anything on screen at the start up? also when you click the menu button on the monitor does anything come on the screen then ? if so then its in your opertating sytem settings , disply settings e.c.t, i really need more info to help you solve this , the best thing i can suggest for now is to try the lcd on another computer a friends computer maybe , before considering the monitor is toast , hope this helps some way , good luck !
Posted on Nov 16, 2007
viziks
  • 220 Answers
SOURCE: Constant switch between ON/OFF/source
Does the menu controls work on front panel?If so you can try factory reset or Recall as it is called on some monitors.
Posted on Feb 27, 2008
  • 7 Answers
SOURCE: ViewSonic VX922 monitor - black screen - green power light flashes
PLEASE read Carefully so here is a fix for the green blinking light ...the monitor is going into shutdown....protect mode......THIS is ...Only for the seasoned electronic service tech ......YOU NEED TO BE into Electronics ..or have electronic background and know how to solder to do this........I been doing repairs for 30 years now ..............After extencive troubleshooting and replaceing a lot of electrolitic caps on the inverter board and spending about 10 hours doing so ....i decided to eather go for broke and blow this up more or trash the unit......................Well my blinking light deal went away...my monitor you could see it trying to start and just shut down............first of all make sure you have no broken solder work on the inverter board or swelled up caps ...Thay use lead free solder so the solder work sucks also...........I did pull the main buss line from the inverter pc board that runs the transformers to test to see where the trouble is.....found its at the high voltage end of the inverter board and The viewsonic 922 uses a protection ic on the inverter board and it tells the controll ic whats the High voltage status of the inverters.....I soldered a 47uf @ 25 volt cap on pins 7&8 of ic-u2 [ bi3101a ] Pin 7 is posivtive pin 8 negative of the cap.... and then soldered pins 10 and 11 togeather on the other side of the ic.......ITs fooling that ic telling the main controll / protect line thats all is well........I would guess the whole deal is LOW inverter voltage or maybe a surface mount device thats going to go........could be low resistor tolerence also............The monitor been working for a week now.........Always on.....anyways........YOUR problem may just be bad solder or bad caps...........if you Have a electronic background or have a friend that works on electronics have him look at the caps.see if any or swelled or rounded on the top of the caps..Also chect the main plug that goes to the LCD backplane to make sure its in correctley................if all that checks then the problem is ON THE INVERTER BOARD ONLY ......befor doing what i have done......I also have a Viewsonic VA-800 that had some of the same problems also ,but it had a lot of lines on the video.......I replaced the,,,,, 2.2 mic @ 50 volt cap in the middle of the main board on it and its still running.....but has about 3/8 of white traces following all the words on the desktop...[[[ anyone that knows this fix i would like to hear from ]]] ..........NOTE if you dont know about electronics...dont attemp any of this......their is a lot of voltage on the inverter board........my answer is that these monitors are JUNK...poorley built units.....
Posted on Oct 05, 2008
bammbammfran
  • 159 Answers
SOURCE: Dell SP2208WFP Flat Panel Monitor goes straight to power save mode
If the monitor is not turning blue that means it isn't picking up on the signal that is coming to it.
Pushing the power button on the monitor should make the monitor work and give you a no signal note if it isn't getting signal.
If it won't power on with its own power button you maybe having a low voltage problem in the monitor itself which isn't giving it enough to fire up after it has been sitting.
Just a note these monitors use and make power even when they are off, unless they are unplugged.
I'm thinking along this route also because when you said you unplugged it for a while that it did turn back on.
Only way to verify it, is to double check the monitor on another computer. and if it is the same then it will have to come apart.
Power issues are very common in lcd monitors, Lots of heat in a confined space. The bigger they get the hotter they get.
You would think they would have incorporated internal fans in these by now. But then they wouldn't sell as many !!!
bammbammfran
Search and you shall find me !!
Posted on Oct 15, 2008
SOURCE: audio adjust screen pop up
I contacted ViewSonic with the same problem. They told me to turn off the monitor and unplug all the cables. Then hold the power button on the monitor for 10 seconds. Turn it back on and it should be gone.
If that doesn't work, I was told to do a memory recall on the monitor by pressing the 1 button and selecting memory recall from the list. It sets the monitor back to factory settings.
I haven't tried any of these yet but hopefully they work for someone.
Posted on Jul 19, 2009
My screen is saying burn in and keep switching colours all the time.(white,red,green,blue.
You may need to send in unit for service because your unit is unable to go to sleep mode when the signal cable is disconnected or the PC is turned off. Please call ViewSonic Customer Care for support.
Although this will not hurt the monitor, you just need to apply an active video signal to get a display correctly. However, it will not work as expected to go into sleep mode. You'll need to call ViewSonic Customer Care to get this taken care of.
May 09, 2014 | ViewSonic VA721 17" LCD Monitor
My Viewsonic VX924 monitor is not working on the DVI input. Have checked output from graphics card output and lead on another monitor, ok. When digital input selected, screen goes blank then reverts to...
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Feb 27, 2010 | ViewSonic VX924 19" LCD Monitor
Viewsonic VX2255wm - worked this morning - dead this afternoon?
The problem you have sounds like the inverter board has failed it can be repaired by replacing the inverter board which may be a cheaper option than buying a whole new monitor, you can do a search online for lcd repairs and spares to find the part you looking just state your make and model and price one up.
But before you do do that, and you feel confident that you could take the back cover off the monitor, you could have a look for blown capacitors, they are quite a comman fault in lcd monitors, once the back cover is off check the power supply board, it will be where the power cord plugs into the monitor, The capaciters are barrel like in shape with silver tops, check for any leakage from them or on the board surrounding the capacitors, also make sure they are fully flat at the top, if they are slightly domed or pretruded they will need to changed. post back your findings if you do find any bad caps ill will try to explain how to get the right ones and what do to. cheers.
Feb 01, 2010 | ViewSonic VX2255wmh LCD Monitor
The digital input does not work
Make sure that you dont have both VGA and DVI connected at the same time. Just DVI will do. Reboot and see if you get POST. Or te dos screen that the computer dose in the beginning counting somethings.
Mar 07, 2009 | ViewSonic VA1930WM LCD Monitor
Samsung monitor and mac os
Please do not adjust RGB unless you know what you are doing.
For critical color work, you will need to use a photospectrometer and calibration software to analyze what your monitor is spitting out.
There are a million obvious reasons you should not trust your eye making arbitrary RGB adjustments off the hip.
Feb 15, 2008 | ViewSonic VX2255 Monitor
Jan 18, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic monitor seems to be stuck in sleep mode
Nov 16, 2007 | ViewSonic VA1703wb Monitor
'memory recall ok' displayed always on the screen. Does not go even if selected yes or no. Why?
I got the problem solved. The other day i called up the viewsonic tech support, service engineer visited and changed the switches inside. the problem got solved. So call up the tech support of view sonic at (india)
We need the following details to create an RMA Request for your Product.
Once an RMA request is created our service Engineer will contact you within 2 Business Days to attend the call.
1.Customer Name
2.Phone no with STD code
3.Complete Address
4.Model and Serial No of Product
5.Description of problem
We can be reached on this email address or through phone on our Toll free No1800-11-9999 or Toll No:-011-26990006
Have a Great Day Ahead.
Thanks & Regards
ViewSonic India Technical Support
bye
Nov 04, 2007 | ViewSonic G90fb 19" CRT Monitor
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
