Question about Brinkmann 805-2101 All-in-One Grill / Smoker
Need a new firer box
I have a brickman smoker grill that needs a firer box
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
You can order here.
www.brinkmann.net
I hope this helps.
Posted on Jun 17, 2010
WE HAVE A BRICKMAN GAS GRIL #810-8411-5 AND GAS IS NOT GETTING THRU. WE HAVE CLEANED IT OUT COMPLETELY, NOTHING IS BLOCKING ANYTHING, BUT IT STILL WON'T LITE. WHATS OUR NEXT STEP
Myra, the problem lies with the grill's gas regulator and how the tank was turned ON. Or the tank is empty.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
Aug 25, 2011 | Brinkmann 810-8410-S Stainless Steel...
I need to take the Tray Smoker out of my grill to replace the ignitor but it only comes partially out. How do I get it all the way out? I have a KBGS292LSSO grill
When you slide the smoker box and smoker tray out of the face of the grill, you may have to lift up the slightly lift up on the front of the slide, to remove it entirely from the grill. Once the slide is pulled out far enough to remove the smoker box, remove it first and set aside. Then continue to pull the slide all the way out, lifting the front as it reach the face of the control panel.
In case you have misplaced your Owner's Manual, I have included a link to it that you can download & print for future reference. http://www.appliancefactoryparts.com/content/pdfs/150240-2.pdf
Check out page 13, if you continue to have a problem.
I hope this has helped you and thanks for choosing FixYa.
Jul 26, 2011 | KitchenAid KBGN292LSS\KFGR292LSS Grill
Not sure how to use the smoker, any tips
Typically, you soak the wood chips of your desire, mesquite, etc for about 20 to 30 minutes in water. Drain them and put them in the smoker box. Use the grill as you normally would. For best results you should turn down the main burners, close the lid to hold the smoke from the smoker box inside the grill, and slow cook your food.
Jul 07, 2011 | Fiesta Blue Ember Gas Grill
Don't have inside of the grill
You have 2 options. Return the grill to the place of purchase and exchage for a new one, that has the Owners Manual. I suspect that the retailer will fnd one for you out of another box. OR you can contact Brinkmann Customer Support (800) 468-5252. In both cases, you will need to have your Proof of Purchase.
Jul 05, 2011 | Brinkmann 805-2101 All-in-One Grill /...
How do i use wood chips while grilling
If your grill came with a smoker box, you soak the wood chips of your choice in water for aprroximately 20 minutes, drain them and put them in your smoker box. Then cook. If your grill did not come with a smoker box, you can purchase one seperately.
Jun 19, 2011 | Char-Broil Commercial Stainless Steel...
Need new grades
If you're looking for new cooking grates, you can either purchase them directly from Thermos @ their online website. Or you can save money and use generic ones that will fit your model grill. Most of the home centers, hardware stores and big box discount stores, sell universal fit generic ones, that will fit most grills. Measure yours for the size you need and pay one or two of them a visit.
Hope this helped you. Please let me know. Thanks and Happy Grilling!!
Jun 17, 2011 | Thermos Quick Set Gas Grill 4000
I need instructions for a viking gas grill...I have the smoker insert and need to know how to use the grill to smoke a round roast or tenderloin.
In order to use the smoker box, remove the last set of porcelain grids and flavor generator plate on the right hand side of the grill. Set the smoker box in theopening so that the front and rear tabs rest on the grill frame.
Always soak the chips in water prior to putting them into the box. Use the "HIGH" position to start the chips smoking, then reduce the heat to a lower level to prevent them from drying out and flaming. If the wood chips do flame up, add a small amount of water to extinguish the flame. Use
caution when adding water to a hot box to avoid steam burns. This tray may also be filled with water to produce steam.
Whether smoking or steaming, the grill should remain closed as much as possible to maximize the effect. During extended roasting periods, it is normal to add fresh wood chips and water to the box several times. Limit the amount of times the canopy is opened-each peek adds about 15 minutes to the cooking time.
Wait until Smoker Box totally cools before trying to remove it.
Enjoy you roast or tenderloin!
Feb 10, 2011 | Grilling
Need help smoking briskett on Char Broil Grill with smoker box
wood chips in the fire box. very low heat. around 200 degree.
maek sure the wood chip is wet and produce smoke. you need to monitor this through out the process.
briskette in the grill side without any heat. depends on the sixe and the thnikness of the meat, you need approximately 12-20 hours before meat become tender.
here are few web site you can get some information
http://www.smoker-cooking.com/howtosmokeabrisket.html
http://bbq.about.com/cs/brisket/a/aa111503a.htm
http://www.wyntk.us/food/smoking-brisket.shtml
http://www.bbq-fyi.com/how-to-smoke-brisket.html
May 29, 2009 | Char-Broil CharBroil 4637318 Grill
Parts for New Braunfels Black Diamond Smoker
i need replacement grilling grates for my black diamond smoker can someone help?
Apr 09, 2009 | New Braunfels Black Diamond Smoker...
Smoker Grill
i just bought the same grill at a yard sale but it came with no instructions. did anyone find a solution for it or a website??? please email me at Lovrofmac@aol.com
thank you!!!
Apr 20, 2008 | Brinkmann 810-5301-6 All-in-One Grill /...
Brinkmann 805-2101 All-in-One Grill / Smoker Logo
67 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
