Question about Dell Latitude D600 Notebook
When started it says pri hard drive not found and no bootable devices found
  • 922 Answers
You hard drive has failed. Take it to a service center and have it replaced.
If you are lucky the service center may be able to recover your data from the old hard drive.
Otherwise, restore the last backup you made of your data to the new hard drive.
If you don't have a backup then you have just learned the hard way how important it is to backup your computer. The bright side is that it is very unlikely that you will make this mistake again. Check out Mozy.com for a very inexpensive backup solution.
If this helps please vote for my solution.
Posted on Jun 05, 2010
Free usb reboot
You might want to boot from a USB device, like an external hard drive or a flash drive, for many different reasons.
When you boot from a USB device, what you're actually doing is running your computer with the operating system that's installed on the USB device. When you start your computer normally, you're running with the operating system installed on your hard drive - Windows, Linux, etc.
How To Boot From a USB Device
Change the BIOS boot order so the USB device option is listed first. The BIOS is rarely setup this way by default.
If the USB boot option is not first in the boot order, your PC will start "normally" (i.e. boot from your hard drive) without even looking at any boot information that might be on your USB device.
Tip: The BIOS on most computers list the USB boot option as USB or Removable Devices but some confusingly list it as a Hard Drive option, so be sure to dig around if you're having trouble finding the right one to choose.
Note: After setting your USB device as the first boot device, your computer will check it for boot information each time your PC starts. Leaving your computer configured this way shouldn't cause problems unless you plan on leaving the bootable USB device attached all the time.
Attach the USB device to your computer via any available USB port.
Note: Creating a bootable flash drive or configuring an external hard drive as bootable is a task in itself. Chances are you made it to my instructions here because you know whatever USB device you have should be bootable after properly configuring BIOS.
  • Restart your computer.
  • Watch for a Press any key to boot from external device... message.
  • On some bootable devices, you may be prompted with a message to press a key before the computer will boot to the flash drive or other USB device.
  • If you do nothing, your computer will check for boot information on the next boot device in the list in BIOS (see Step 1) which will probably be your hard drive.
Note: Most of the time when trying to boot to a USB device there is no key-press prompt. The USB boot process usually starts immediately.
  • Your computer should now boot from the flash drive or USB based external hard drive.
Jan 02, 2015 | Computers & Internet
What do you do if no bootable device is found
When your pc starts as no bootable device that means it either can't see the hard drive or it's trying to start from the dvd or floppy? Do you know how to get into the bios menu?
Aug 23, 2014 | Compaq Computers & Internet
HP 255 How do I setup bootable disk ? I have tried esc and seled internal cd-dvd room but it doesn't work
On the HP System, you'll need to press the escape key as the system is starting up, and then hit F9 to get to Boot Device Options. Once there, you can set the boot order. After you've set the boot order, you'll also need to make sure that you have bootable files in the device that you've selected as the first boot device.
For example, if you've set the first boot device as CD-ROM drive, and the second is the Hard Disk Drive, then you'll have to make sure that there's a bootable CD/DVD in the drive when you start the system. If no bootable files are found on the first boot device, it'll automatically check the next boot device, which is the Hard disk and start booting from the Hard disk.
GuruAid
May 18, 2014 | Computers & Internet
No bootable device found
The Hard Drive is not starting up. You can check the Hard Drive and detach/re-attach. If it's a HDD failure, you will need to replace it.
The other issue could be HDD controller on the motherboard.
90%of the time it's a HDD failure.
Nov 23, 2013 | Computers & Internet
When laptop says no bootable device
re-seat hard drive and check settings for boot devices in bios.
run ibm diagnostics and see if it is seeing the hard drive . if it is run the hard drive tests if they pass then you probably have misconfigured the bios settings somehow. if the hard drive is not found or fails the tests then im afraid your going to have to look in to an exspensive data reclamation service, your best bet there is go to the hard drive manufacturer or even ibm itself.
Jun 13, 2013 | Lenovo Computers & Internet
Loveno S10-2 - No bootable device found
Make sure your hard drive has higher priority in the boot options in BIOS. If it still doesn't boot then you will need to replace your hard drive. If it shows no hard drive in BIOS then the drive is most certainly bad and needs to be replaced.
Dec 02, 2012 | Lenovo IdeaPad S10-1211U Netbook
Why is my bootable device not found
It is more than likely the hard drive has issues, have the hardware tested for possible replacement.
Jul 27, 2012 | Acer Aspire One PC Notebook
Starting my laptop i get this message internal hard disk not found To resolve this issude . try to reseat the drive "which i did" no bootable devices stike f1 to retry boot , f2 for setup utility...
Hi ajmedina89,
If your system wont boot up and has a no "bootable devices" message, is often caused by a defective harddrive. I recommend to try a different HDD before replacing your system HDD to isolate the issue.
Hope it helps.
Thank you for using FixYa.
Apr 25, 2011 | Dell Inspiron 1545 Notebook
My LaCie hard drive is listed in preferences but it does not boot. Your suggestions?
Have you ensured the Lacie HDD is bootable? IMC, external drives that does not contain boot files or not-formatted in bootable mode cannot boot your device.
Try formatting your Lacie drive into bootable mode. Right click -> Format -> Check "make device bootable" and click start. THis shoudl help.
Mar 05, 2011 | LaCie Computers & Internet
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Dell Latitude D600 Notebook Logo
64 people viewed this question
Alun Cox
