Question about Maytag Ovens
Oven stays on
I have a maytag dependable bake plus convection oven model CRE9830BCM. The oven automatically turns on when the oven is plugged in to the receptacle. I have to turn the breaker on and off to use it. Thanks Bill
  • Anonymous Mar 31, 2014
    trying to find out what accutemp on ovens means
The oven won't come at all.
Posted on Jan 06, 2012
  • frankie_lynn Jan 06, 2012
4 Suggested Answers
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
catriver
  • 878 Answers
SOURCE: Jenn Air wall oven-Broiler element comes on and will not turn off....
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
Posted on Apr 10, 2007
SOURCE: oven won't light.
Localwonder gave a more comprehensive answer, but I wanted to share my recent related experience too:
Same model: MGR5750BDW
Oven was not heating up, or would sometimes and not others. Broiler worked fine. The nice thing is that the broiler igniter and the oven igniter are the same part. So I swapped them until I could get a replacement part.
Before I did anything, I turned off the gas!
To take out the broiler igniter: there's one screw right near the front of the oven that holds the burner assembly in place. Remove that, gently pull the assembly off the gas nozzle off to the left. Then where the wires from the igniter go into the back wall, remove the screw that holds the little door, remove that little door, and then gently pull the wires through until the connector comes through the opening. I also found you can go behind the stove, remove the back panel (which is easy) and see the igniter's connector.
The oven one: remove the floor of the oven by lifting it at the back, and then lift it out towards the back of the oven. Then you can see the igniter at the back of the floor of the oven. remove the two mounting screws, and then gently pull the wires until the connector comes through the insulation.
The bad igniter looked like it had burned down to bare metal in a big patch...not sure if that's the actual problem, but in any event, I installed the good igniter in the bottom (gently pushing the reconnected connector through the insulation, and feeding as much of the wires down in there as well), and the bad igniter in the broiler position (since that was the easiest one to access and replace, it'll be easy enough to replace when I get the parts). Tested, and everything worked great. And I could watch the bad igniter light up, and never light, confirming that it was the igniter itself that was the problem.
The best part, for this stove anyway, -- the ONLY tool needed was a #2 phillips screwdriver. Really. All told, maybe an hour of work, nothing intense. And free -- so if they both worked, it would have spared me ordering a part that didn't need to be replaced!
Posted on Jul 11, 2010
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
I just replaced my baking element in my oven, and when i turned the breaker back on, now the new element automatically heats up by itself and stays on....with everything off. The only way I can get it to...
If the only wires you disconnected and reconnected were the 2 on the element itself, the bake relay is fused. Depending on the brand and model, the bake relay can be located on either a realy board or the electronic oven controller. Either the controller or the relay board (if present), will also need to be replaced.
Apr 16, 2011 | Stoves Ovens
My Maytag oven (mgs5870adw) isn't getting as hot as it should.The boiler works and all of the burners work. I haven't confirmed my problem other than noticing that things don't cook evenly and/or take way...
mlong9876 - I am having the same problem as you posted re: Maytag (mgs5870adw). I am trying to arrive at the same resolution changing the lower igniter in my same model oven. Were you able to remove the lower oven plate to access the top of the burner and igniter with the convection bake fan housing in the back? I am having difficulty getting to the igniter.
Mar 13, 2010 | Ovens
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
How do I use this oven? Is it working correctly?
It would seem that the oven is small enough that a fan to flow the heat from the unit would be in use for both convection and bake modes. Usually convection ovens will have a "burst" of fan action during the bake process and it is not a steady fanning of the air that would dry out your cookies, ect. I have a small oven / microwave and my larger oven is a GE that has the "burst" convection that I described. Might not be that much help, but it's hard without more info on your unit. sometimes the model is behind the oven door.
Nov 04, 2009 | Jenn-Air Ovens
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
On a Amana EvenAir convection Plus oven the convection blower comes on during the regular bake cycle.
There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
Oct 12, 2009 | Amana AOCS3040 Electric Single Oven
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Bosch oven
looks as though youre circotherm element has blown (open circuit) you will need to remove oven and check with multimeter should read around 35-37 ohms on 2.5 kilowatt heater if open circuit will need replacing easy to do on most ovens and no too expensive around £30-£35 for element depends on model and output power.
hope this helps
Jan 17, 2008 | Bosch HBL 745 Stainless Steel Electric...
Ovens Logo
349 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
