Question about Husqvarna Designer I
Help with patches
I am trying to EMBROIDERY onto a patch that will be sewn onto a jacket. my problem is that i can't seem to get the name center on the tag. i have the husqvarna designer 2 .
  • 201 Answers
Print out your embroidery design and cut this out around the perimeter of the hoop grid. Pin to your material where you want the design to be. Hoop stabilizer only. Place your fabric/paper design sandwich on top of the stabilizer, being sure to get the cross hairs lined up with the notches on the hoop. Pin fabric as close as you can get to the edge of the hoop, or use spray temporary adhesive, or double-sided tape around the outside of the stabilizer also works great. Load design onto machine and put on the hoop - paper still attached. Turn handwheel so that the needle enters the paper at exactly the centre - adjust hoop position if necessary. Remove paper template, use Fix to baste fabric to stabilizer, and sew the design. I actually prefer to cut the paper template fairly close to the design and use chalk cross hairs on my fabric to line it all up. The good thing about doing it this way is that you don't have to re-hoop if it is off-centre - just pull the fabric off the stabilizer (that's why temp. adhesive is easier than lots of pins) while the needle is down in the centre, and manouevre it to where you want it before basting down.
Pam
Posted on Apr 15, 2008
SINGER QUARTET FOUR IN ONE HOOP ERROR
There are a couple of reasons that this can happen. First, download a patch on the singer Futura support site, www.futura-support.com. Download the patch, close the Futura program and double-click on the downloaded file. It may help with your error.
The second reason it can happen is because the USB plug on these machine is out a little too far, and the cable often doesn't seat quite as solidly as it should. Put the cable plug in the machine, making sure that it sits squarely and securely, and tape it in. When you unplug, do so from the computer side and leave it in
If you've applied the patch and taped the plug, the third reason might be the USB cable itself might have a loose wire, so that it works some time but not all the time. If that seems to be the case, try another cable.
Aug 05, 2014 | Singer Futura XL-400 Quartet 4-in-1 Sewing...
Need a patch for Singer Futura XL400 windows 7
I don't why you need a patch for Win 7; the software was created for and works on Windows XP, Win 7 and Win 8 without alteration. However, there IS an update patch available at the Futura support site, www.futura-support.com. Click the My Machine model link at the top, select your machine, and then select Software on the left, and you can download the patch.
Jun 29, 2014 | Singer Futura XL-400 Computerized Sewing...
Dongle won't work
did you try the dongle in another port... yes if you can find the patch you can load it onto a flash drive or sd card and then upload it over to the new pc
Dec 28, 2013 | Husqvarna Designer I
My vip embroidery system won't load onto my computer
you may need a patch or a update or upgrade depending
on which windows you have.
Nov 17, 2012 | Husqvarna Designer I
Setup
If you want to sew with it, don't hook it up to the computer. You only need to connect it for embroidery.
There is a patch for the ce-200 software at
futura-support.com/downloads/patch.htm
I installed the XP patch and told Windows to run the software as an XP program.
Nov 30, 2011 | Singer CE-200 Quantum Futura Computerized...
I cannot seem to down load my software onto my computer tried it on vista tried it on windows 7 i am peeved
Have you downloaded the patches for your software to upgrade to Vista? I would suggest that you visit the Singer support page on their website and read through the patches information.
http://www.futura-support.com/downloads/patch.htm
Your software is probably built for XP operating system so you would need to patch it for the newer Vista - there is not yet a patch for Windows 7.
Oct 10, 2011 | Singer CE-200 Quantum Futura Computerized...
My embroidery (Singer Quantum XL6000) requires the Windows XP and lower on a computer to acquire additional patterns, will it work with Windows 7?
Mine works with Vista. :)
Just install the XP patch (futura-support.com/downloads/patch.htm) and tell Windows 7 to run the software in XP mode.
Oct 07, 2011 | Singer CE-200 Quantum Futura Computerized...
My software won't run on the vista windows
I had the same problem. I called a singer service center and he told me that was a major issue with the futura....no software made for Vista. I was determined to find a solution and finally found a patch. Here you go: http://www.futura-support.com/downloads/patch.htm#
May 12, 2009 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
101 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
