Question about Garden
Lawn mower idling rough - Garden
  • 10,319 Answers
Replace the spark plug if not done so as of yet. This is required every year on air cooled engines
Also drain the float bowl of sediments. if the new plug did not help you out very much
Carburetor cleaner spayed in to the needle and seat area will help immensely
Posted on Jun 05, 2010
My lawn mower fires up but idles slow and rough
No adjustments. Automatic governor. Replace spark plug. Ensure blade is sharp and oil is full. 30w oil. Always put Stabile in gas. When you remove spark plug pull rope several times to blowout cylinder. Spray a little WD40 in spark plug hole, then pull rope several times. Spray starting fluid in spark plug hole, replace plug, ensure plug wire snaps on tight. Clean replace air filter.
Aug 09, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Yard machine model 11a-41mb029 idle
Hi, idle is not adjustable unfortunately they only have fast and a high rough idle, regards Phil.
Jun 02, 2012 | Garden
Rough idle on mower
Remove air cleaner and replace filter. Spray carb cleaner in choke at choke flapper. Remove carb float bowl and clean. check float bowl screw for hole thru it, clean out with thin wire if present, reattach bowl and screw, ensure gasket on top of bowl is good, Have mower model no. get new bowl gasket kit at mower repair store.
May 25, 2012 | Toro Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Poulan pro 625 lawn mower idles slow and rough
Try changing your plug and check gap and put in some fresh fuel. Empty out the old stuff especially if it has been there a while. Also check your low idle setting on the carb open it up a half turn for starters. Good Luck...
Aug 27, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Engine starts. Idles rough then dies. sparkplugs being fouled in one use.
Sounds to me as thought their is either a fuel problem (needs carburetor rebuilt/readjusted) or a considerable amount of oil is getting into the combustion chamber. I would tend to lean towards the fuel system. Have you run any fuel system cleaner thru it?
Aug 29, 2010 | Husqvarna 21" Lawn Mower with Honda GCV160...
Mower idles rough and stalls at times. Also blows
look by the carboreter and there is a little screw with a spring. turn the screw a half turn and try to start it, then try another half turn, and keep expirementing.
Jun 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
