Question about Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome...
I am tryin to retighten my moen single faucet
I am tryint to retighten my moen single faucet (the part under the ball assembly) and I am unable to tighten past a certain point and wondering why it keeps getting jammed (not cross threaded). Is there a specific way to line up the parts?
  • 34 Answers
The plastic collar that sits on the ball has locating tabs and the v in the middle should point to you.
The ball also has a slot that locates a pin in the body of the faucet to stop the ball spinning arround.
Posted on Jun 07, 2010
I have a Moen single lever bathroom faucet which is leaking. It has two screws on the under side of the throat. When I remove the screws the plate does not come off easily and I do not want to bend it out...
i would like to help you w/this but i need some information first: 1) do you mean the faucet is running into the sink or it's leaking from the faucet body? (or from under it) 2) do you know the model of the faucet as this will tell me whether it is a cartridge system or a ball co.ck.
Jul 30, 2011 | Moen Home
Delta single lever faucet leakingafter bing shut off.
Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
Jun 26, 2010 | Delta & Single Handle Shower Faucet
Im tryin to remove the ball stem #212 off my faucet?
Remove handle and on top it has a cap that has to be removed to access the ball it will require maybe a strap wrench or chanel locks with something on teeth to keep it from damaging top cap.
Remove cap and it will give you access to ball turn .
Mar 27, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Moen faucet removal
you will have two mounting nuts at each end and two water line to disconnect for removal under the sink on any faucet made
Feb 13, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
The cartrige inside my moen faucet leaks
moens website. they have parts break down and diagrams
Nov 30, 2009 | Moen F7425 Chateau Single-Handle Kitchen...
I have a single handle Moen kitchenfaucet. I
You turned the faucet body when you tightened faucet you need to loosen and reposition body so handle goes left and right equally and retighten while making sure faucet body does not move
Nov 12, 2009 | Moen Plumbing
Moen - Single lever bath tub faucet - cold water only
moen does not have a ball and washers....sounds like a Delta maybe. Moen uses cartridges. Either way sounds like a balancing spool problem....but you will need to make sure of the right name for the faucet to get the parts.
Aug 17, 2009 | Plumbing
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
194 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
