Question about Dryers
Water collects in the bottom of dryer after use
    President:
  • 512 Answers
Dryer and vent need to be cleaned, holding moisture in due to excess lint.
Posted on Jun 07, 2010
My td c700e no longer collects water in the condenser but comes out of the bottom. why?
at bottom on the back pannel should be a trough that water collects in.............there should also be a micro switch and a float.......when float rises it trips micro switch that starts pump to send water to the collectin tank.........
cheers
Jul 31, 2014 | LG Dryers
WONT DRY
Hi there, if your dryer is a condensing dryer then perhaps you need to empty the collector bottle , its is a compartment on the side of machine , open this and remove the bottle , this must be done after at least two sessions of drying. On the other hand if your dryer is of the vented type with a 4 inch flex vent it must be vented through the wall to the outside with no kinks in it , the reason for this is the water turns to vapour , and must exit the machine or you will have clothes that are still wet and water will collect at the bottom, its the same principal for the condenser machine only you have to empty the bottle of condensed water or the same result will occur.
Hope this is of some help to , Cassyjoe.
Nov 07, 2012 | Washing Machines
My Hotpoint Aquarius Condensor Dryer seems to be collecting water behind the filter unit at the bottom of the machine. The drawer where the water is supposed to collect is empty. I keep the filter unit...
there is a line/tube the runs into the back of the drawer which is clogged, you will need to take like pipe cleaner or a stiff wire and run it into the the drain line/tube , Tim
May 29, 2011 | Dryers
WHIRLPOOL AWZ8577 somehow my dryer is getting the water out through the little tube at the bottom of the back. I want to know how to make the machine collect the condense water into the container again...
whirlpool awz8677 i am getting the same problem with my brand new dryer. Getting water coming out through the bottom front and back. Anybody know how to solve this problem? Thanks.
Oct 23, 2010 | Dryers
I just got a malber 1000 washer/dryer. Can it be used as a dryer only?
NO THIS UNIT USES CONDENSED DRYING AND WILL WET THE CLOTHES BEFORE IT EVEN TURNS ON THE HEATER. BASICALLY YOUR COMBO USES STEAM CIRCULATION THRU YOUR CLOTHES. AS THE SMALL WATER PARTICLES IN THE STEAM MOVE THRU YOUR CLOTHES IT COMBINES WITH SMALL WATER PARTICALS IN THE CLOTHES(THINK OF 2 WATER DROPS COMBINING ON YOUR WINDSHEILD AND HOW THEY ABSORB TOGETHER) WHICH RISE TO THE TOP OF THE TUB AND COLLECT INTO WATER AGAIN. THEY THEN ROLL DOWN THE SIDES OF THE TUB AND COLLECT AGAIN AT THE BOTTOM TO BE PUMPED OUT. BEFORE THIS PROCESS EVEN STARTS THE UNIT WILL ACTUALLY ADD WATER TO GENERATE THE STEAM. MOST PEOPLE FIND THAT IF THEY WANT TO JUST FRESHEN UP SOMETHING, IT WILL END UP DRENCHING WET IN THE FIRST FEW MINUTES.
Jan 18, 2010 | Malber WD1000 Front Load Washer/Dryer
Water is not draining away throguh the hole near
the drain is probably frozen, unplug unit and defrost manually, use a hair dryer to melt the ice around the drain , be careful not to melt any of the plastic
Nov 03, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water pooling underneath bottom drawers
May 28, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
No water collecting in my hotpoint aquarious cdt00
If you pull out the front left bottom filter and feel inside and find that it is wet, then there is a blockage, this stops the water getting to the water container.
Clean as much fluff and gunge as you can from this compartment, and feel for and locate a small drainage hole at the rear, get a plastic bag tie or similar, and poke the hole clear.
Hopefully, this will solve your prob.
Plz rate my solution.
Thanks.
I am assuming that the pump is working o/k
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
