Question about Jenn-Air JGW8130A Electric Single Oven
Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
About two years ago, we had a major power surge run into our house, which made the display/clock on our Jenn-Air gas oven go out, among other appliances in our house. Is it possible to get this back? If so, how? The oven itself works great, but it would sure be nice to have the display/clock back. Thanks SO much for your help!!!!!
I have a Jenn-air Model # JGW8130DDB (30" gas wall oven). It is brand new, never installed, but has been in storage 2-3 years. When plugged in, I get no power to the oven (no panel, no light, etc.). Breakers and outlet have been checked. Could there be an internal circuit breaker? Any suggestions? Thanks in advance.
  • turkn8or Apr 11, 2008
    This is a 120 volt gas oven (Jenn-Air JGW8130DDB). The drop-down did not allow me to pick the exact model number of my oven so I chose the closest model. I'l check the internal electrical connections to make sure they are secure. Thanks
    Novelist:
  • 184 Answers
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Posted on Apr 10, 2008
  • 1 more comment
  • DAVID LOGAN Apr 11, 2008
    OTHER THAN THE CONTROL, THE ONLY OTHER THING THAT COMES TO MIND WOULD BE A THERMAL FUSE THAT MAY BE IN THE CONTROL AREA. ALSO, CHECK FOR A 120 VOLT SUPPLY TO THE CONTROL. THE WIRING DIAGRAM WILL POINT TO THE CORRECT WIRES TO CHECK. IF YOU HAVE 120 VOLTS TO THE CONTROL, BUT NO DISPLAY, THE CONTROL IS DEFECTIVE.
    ARE THERE TWO DIFFERENT OVENS POSTED ON YOUR
    REQUEST? AT THE TOP IS A WEAK DISPLAY BUT OVEN WORKS O.K.
    FURTHER DOWN, THERE IS A POSTING OF OVEN WITH NO POWER, NO DISPLAY, NOTHING.
  • Marc Hall
    Marc Hall Nov 11, 2013
    I have a 14-33-754 Thermador it has power to it, gas range is okay, igniters work but the oven controls are out no lights totally unresponsive
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions! info@fixyourboard.com
Jun 05, 2017 | Jenn-Air Ovens
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Jenn air svd46800 not working
I'd be on the hunt for a burned fuse I could replace, on those two circuit panels. If no fuse(s) can be found, I would be sad to think the circuit board itself got fried, and new ones can be goofy expensive, so here's to you finding a burned fuse!!
Jan 14, 2014 | Jenn-Air Ovens
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
Aug 20, 2011 | Jenn-Air Electric Single Oven
Double oven (WW30430B) got the similar display dim/disappear prob
If you haven't already, replace the capacitors on the clock module. I had the same problem with a similar oven. See this link for more info:
http://www.badcaps.net/forum/showthread.php?t=7902
Aug 23, 2009 | Jenn-Air JJW8530C Expressions Collection...
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Ignitor not working
Check the ignitor, Make sure that the connection are good and tight. If they are then look at your control board which is located behind your clock. Then check your relay also.
Feb 20, 2009 | Jenn-Air JGW8130A Electric Single Oven
Oven digital lighted display is dim
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Display blank
Every time I have seen this problem, it has been a bad display assembly. These are fairly easy to change yourself, but the part is kind of expensive, I think in the $150-$200 range. Hope this helps!
Aug 21, 2006 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JGW8130A Electric Single Oven Logo
404 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
