Question about HP LaserJet 3330 All-In-One Printer
Scanner error 52 during opening scanner bulb warming up error scanner error 52 what should i do
  • HP Master
  • 4,737 Answers
If you can open it, please reseat the scanner flex cable after turning the machine off. For full details on how to troubleshoot, please refer here.. Hp error code 50 - 59 Good luck. Thanks for using FixYa.
Posted on Jun 05, 2010
How do I fix the error code 52 on my HP printer?
The correct solution is to replace the scanner with the correct M401 model not one from an older HP. The scan speeds could be different, the motors could be different which would make the formatter think that the motor was turning too slow.
Jun 11, 2015 | HP LaserJet Pro 400 M401DN Laser Printer
Hp leserjet pro 400 mfp scaner error 52
The scanner initialization did not pass it seems. Try cleaning the glass and white background.
If that doesn't work, the scanner bulb may be faulty - try replacing it.
Sep 09, 2014 | HP Laserjet Pro 400 Mfp M425dn...
Won't go to menu
Had a similar problem on a HP MFC3330
Fixed it with the following video aid:
"how to fix the scanner bulb warming up error hp 3330 or repair 3380 scanner bulb warm up problem - YouTube"
http://youtu.be/lqG_nmi3vC4
Hope it helps...
Jul 27, 2014 | Dell 1600n All-In-One Laser Printer
Scanner Error - Power On Power Off
The "scanner warming up" error is usually caused by dirty glass or mirrors in the scanner assembly. Here is a link to a step by step guide that tells how to open the scanner unit and clean the optics to clear the error.
http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/
Feb 28, 2013 | HP LaserJet 3300 All-In-One Printer
HP LASER JET 2300 52.00 ERROR
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
4. Replace the engine board.
Tallon41
Sep 12, 2012 | HP LaserJet 2300 Printer
Scaner error 52 in my laser jet printer printer model :-hp laser jet 3052 all in one printer
52 Scanner Error
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the FFC connection between the formatter and the scanner.
NOTE Do not bend or fold the FFCs during the removal or reinstallation process.
4. Try connecting the product to a different power source or surge protector.
5. Turn on the power and wait for the all-in one to initialize.
6. If the error persists, replace the laser scanner assembly.
Jul 12, 2011 | HP LaserJet 3052 All-In-One Printer
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Scanner bulb warnning
The 'scanner warming up' error is caused by dirty scanner optics. What happens is the scanner initializes the lamp and starts reading the scanner pickup waiting for the light to get to a certain brightness level. When the optics get dirty from dust or smoke then the light getting to the scanner pickup is reduced so the unit thinks the scanner bulb has not reached the correct brightness so it says wait. What you will need to do is dis-assemble the top portion and clean the scanner optics. We have a step by step guide to do this procedure posted on our web site at: http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/ This should get you back going again.
I hope this helps you out, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 16, 2010 | HP LaserJet 3330 All-In-One Printer
Scanner error 6
Scanner errors are as follows for that model:
Scanner error #
1 = dark find
2 = LMW temp find
3 = bulb warm up from off
4 = bulb warm up from coarse
5 = cal label find
6 = doc original find
7 = LMW final find
8 = cal label find after scan
9 = cal label find prior to standby
10 = doc original find prior to standby
11 = bulb warm up from standby
I would see if there is an original on the flatbed glass (platen), or if something is obstructing the scanner view.
If the error persists, replace the scanner
assembly or the formatter pcb
Apr 22, 2008 | HP LaserJet 2840 All-In-One Printer
Scanner not working - get error message
First, check to see if the bulb lights up, if not you have bad bulb. the bulb can be ordered separately. if the bulb is good, you have a problem with the main board.
Nov 02, 2007 | Epson Perfection 1240U Flatbed Scanner
HP LaserJet 3330 All-In-One Printer Logo
977 people viewed this question
Seeker5211
Seeker5211
