Question about HP PSC 1210 All-In-One InkJet Printer
The cartridge error message seems stuck in memory
The check cartridge light is blinking,and an error message seems stuck in memory on an HP 1210 all in one. I have changed the cartridges, cleaned the receptor heads, turned it off, unplugged it, pushed buttons, and nothing helps clear teh message and allow me to print or copy.
Any thoughts??
  • HP Master
  • 4,737 Answers
Please turn off the printer and disconnect the power chord and the usb cable, open the scanner door/backdoor, etc.. Remove the cartridges and clean cartridges contact points. Leave it for few minutes without any connection. Power on only with the power chord connected and without installing the cartridges and again leave it for few more minutes, switch it off. Reinstall and reconnect all the cables. Restart your system and boot up both the Pc and the printer simultaneously while you keep pressing the power button of the printer. Note that you have to use only the power button to switch the printer off or on. Good luck. Thank you for using FixYa.
Posted on Jun 05, 2010
  • 182 Answers
Actually i think that there may be lots of dust particles inside the printer, better contact an hp authorized service center , i think they will ask for some service charges or may need to change some spare parts , try this first if not working properly dispose the printer and buy a new one, rather than repairing it
Show e on copies and check ink cartridge light is blinking with new ink cartridge
With "E" ,check cartridge LED which is blinking mono or color replace it, or else check paper LED if its blinking check for the paper jams..
Sep 27, 2011 | HP PSC 1210 All-In-One InkJet Printer
HP printer PSC 1210 black cartridge error. The black cartridge does not work and the blinking light is always on when I plug in the cartridge.
Black cartridge error usually means that the contacts on the cartridge have blown or that they might be dirty. That's why the printer says it has a problem. Remove the cartridge, wipe the contacts with a dry cloth and put it back in. If it still gives you the same message, you will need to buy a new cartridge.
Mar 31, 2010 | HP PSC 1210 All-In-One InkJet Printer
Printer ink cartridge not recognized by printer hp psc 1210
some time hp printer does not reconize refill cartridge or cartridge is damage when refilled so change cartridge
Feb 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Check printer cartridge E
Turn off the printer, unplug from wall, wait 5 miutes, plug it in & turn it on. Have the same issue with my husbands 1210 & this is how I fix his about 3x's a week.
Feb 13, 2009 | HP PSC 1210 All-In-One InkJet Printer
Check print cartridge error
clean the brown dotted circuit of both the cartridge and the printer.and then try.it will work.
Aug 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP Psc 1210 All in one
Try to unplug the power cord at the back of the printer while it is still on. After 20 to 30 seconds plug it back in.
Jul 04, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp 1210 all in one printer - error message
Two problems;
1 - This unit cannot be set back to factory settings as it does not have the keypad to enable this functionality.
2.
Most of the time when the error pops up it is due to problems with either the printer reading the cartridge is in from the contacts or the cartridge contacts are damaged.
I should also point out that refilled and remanufactured cartridges are the number one reason for the error but assuming that you are using hp cartridges fresh out of the pack take a look at this link and follow the steps. I would type them out but it even has pictures for easy reference!!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042818&cc=us&lc=en&dlc=en&product=79499&dlc=en&lang=en
If you are not using hp cartridges then replace with genuine cartridges and it will most likely resolve the issue - the printer is able to tell the difference between a new and refilled/remanufactured and often times will reject the cartridge because of this.
Jul 01, 2008 | HP PSC 1210 All-In-One InkJet Printer
Print cradle cannot move error
hi,
this seems to be a hardware problem..... anyway try this...
> unplug the powerchord
> open the rear access door, and check whether there is any paper jammed or any bit of paper or thread stuck inside.... if so remove it
> clean the rollers using a lint free cloth
> close the rear access door
> open the door so that you will get full access to the cartridges...
> move the cartridges to and fro for several times manually with your hand
> close the door
> plug the power chord
> try again to copy multiple pages
thanks and regards
agnel
Mar 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
NEED HELP WITH MY PRINTER
HP PSC 1210 - The Print Cartridge Detected is the Wrong Type * The following message is displayed on the computer: "The color [or black] print cartridge detected is the wrong type" * The Check Print Cartridge light is blinking, and the Check Paper light is off. This problem usually occurs after replacing a print cartridge. Soloution: http://www.whatmobile.com.pk/hp/hp1210.htm
Aug 05, 2007 | HP PSC 1210v All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
477 people viewed this question
Seeker5211
Seeker5211
