Question about Maytag Neptune FAV6800AW Top Load Washer
What does the dc fail code mean on the display
  • 526 Answers
It an unbalance error code more than likely related to a Clutch malfunction. See my Clutch Fix post if you wan to DIY the fix......Rich
Posted on Jun 07, 2010
What does dc mean on the display?
The most likely cause of a DC error code on a Neptune is the clutch assembly.
Oct 15, 2014 | Maytag Neptune Washing Machines
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
Maytag neptune toploader won't finish cycle code dc. What does dc mean?
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer? makes a
more than likely it just needs a little leveling...lift front of washer . there are 2 leveling feet on each front corner under the washer.. they turn like a screw ..just adjust these feet till its level and you should be ok....shake the washer by hand . if it doesnt move it shoud be level,,,,an unlevel washer makes terrible noises ...as you know..thanks and have a great day
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a Neptune TL FAV9800AWW that will not finish the spin cycle. Says it's a circuit or something but all that is fine. Still will not empty with or without clothes.
Are you taking dc or UC errors to the display in spin cycle?
""Says it's a circuit or something but all that is fine."" Who made this assement?
""Still will not empty with or without clothes."" So I understand do you mean that you take no error codes to the display for this issue.?
The FAV9800AW has a different type of display then the FAV6800AW the machine I own. With limited.... no info on error codes I feel you are failing in spin cycle with either a "dc" error or a "UC" error. If so post back and we will go from there. Take a look at this owners issue and see if it similar to your issue.
Take a look through the Service Manual and see if this helps you identify error code types.
If you have water in the tube I can help you get into Service Mode and pump out the water. That will also let us know if the drain pump has failed.
Rich
Aug 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Canon PC785 fails and turns off immediately after turning on. Displays code ''EO'' just befor shutting off
E0 error means Fixing Unit failure. It could be a dirty Thermistor. It could be an open Thermal Fuse. It could be an open Heater Lamp. Anyways, once the culprit has been isolated and corrected, the copier will need to be reset via "jumpering" certain points on DC Controller.
Jun 22, 2009 | Canon Office Equipment & Supplies
E000733-0001 the err means I have the same problem, the same error code: E000733-0001 on my Canon IR3100CN. I cannot pass to service mode...After I switch off & on, the display shows me the same...
E733-0001 Error Code
E733 and machine locks up with progress bar at 98% on boot up?
I would refer this error to a qualified service Tech.
Deals with replacing DC controller, Main Controller and Boot Rom as a set. Also, mention of replacing the Switching Regulator PCB Assembly if the previous failed to resolve.
May 27, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Error Code 63 on Phillips Plasma - what does it mean?
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Mar 30, 2009 | Philips Televison & Video
Maytag washer has error code of dc
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#$
Mar 27, 2009 | Maytag MAH8700A Front Load Washer
Maytag neptune tl washer
A dc error means that the clothing is not being distributed properly in the basket. This usually happens when the machine is lightly loaded. If the load seems o.k. then the problem is probably with the sensor at the side of the basket.
Apr 26, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
135 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
