Monitor displays NO SIGNAL message - Televison & Video
  • dthayes2 Apr 10, 2009
    no input on my monitor
    Champion:
  • 207 Answers
Check if monitor cable is connected properly to both monitor and PC (graphic card). If the cable is connected and pins are undamaged than it must be a problem with your graphic card or integrated graphic, whatever.
Posted on Apr 10, 2008
Monitor display no signal message
Hi. Check the cables if it is firmly connected to the video ports. If nothing happens, try removing and reinstalling the video card then reconnect the cables. It works wonders!!!
^_^
Jun 03, 2010 | HP w2207 Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
VP191b monitor no video Viewsonic
did you activate the monitor port?
Did you check theconnection?
Is themonitor pluged in the wall socket?
Jan 16, 2010 | Computers & Internet
Samtron Monitor 56V Display Problem
your power supply is probably bad. open the case with it unpugged and look for leaking or crowned capacitors. most electronic repair shops can replace them for you
Jan 10, 2010 | Computers & Internet
Screen saver displaying unwanted message
This happens on monitors with a sleep type function. Make sure that the sleep mode is turned off and that it is set to never turn off inside of windows. Then the no signal error should not come on again.
Sep 07, 2009 | Computers & Internet
Monitor starts then goes off, no signal
I would check the LCD against another monitor. It does not have to be a LCD, a regular monitor will do.
This will tell you 2 things, 1. The Video card is good or bad, 2. The Cable is sendinf a good signal.
If when you startup the monitor, you see a display and then after a few seconds it display's a no signal message, this is consistant with a Bad cable or cable ends. or Bad VGA card from computer.
Hope this helps. Good luck..
P.S. If you have move the PC, you may want to open the unit, and re-seat the Card. If the card is not making a solid connect on the board, it will display these syptoms.
Sep 05, 2009 | HP w1907 LCD Monitor
Princeton Digital VL1716 Monitor "No Signal Message"
Roxio Changed Your display settings on the dual display.
Right Click on desktop>goto Prefences>
You should see both monitors indentfy the one and change it to a lower resolution.
Apr 28, 2009 | Princeton Digital VL1716 17" LCD Monitor
Monitor displays signal cable disconnected
Check your VGA connector (from monitor to PC), namely the pins in the connector. It's pretty easy to bend a pin, so that it doesn't make the connection. If you happen to do this to the connection present pins, then the monitor won't know that it is connected and will just display the message you are seeing.
Mar 15, 2009 | Dell UltraScan P1110 21" CRT Monitor
No Signal message
This is a message the monitor displays when the video cable is disconnected or the computer has no video output. Could be the computer is simply entering power save mode. Does the screen come on when you move the mouse or press a key on the keyboard?
Dec 28, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
Televison & Video Logo
405 people viewed this question
Top Televison & Video Experts
Electro Med Services...
