Question about Yard Machines 24A452G700 205cc Briggs Stratton 800 Series Gas Powered Chipper Shredder ()
Engine starts and runs fine until i run about 5 pieces of branch
Thru it. it the stalls and putt-putts to a stop. ocassional black smoke. it is getting good fuel . carb and float are clean/with fuel filter. it will only run with the choke 100%. it immediately starts right back fine. new plug.
  • gilpinfred Jun 06, 2010
    I have just checked ignition module and flywheel. Sure enough the culprit was rust on both of them. A good sanding and WD-40 cleaning with setting the gap did the trick. Rust had built up on both and the two were rubbing. Thanks for putting me on the trail to the firing. I let the thing run wide open for 15 mins. I could throttle up or down with no hesitation. It will now run without being kept choked. Thanks again. Fred
  • 36 Answers
What color is the fire at the sparkplug? if it is blue it is good, if it's red that means that your spark is weak probably your coil is weak replace your coil
Posted on Jun 05, 2010
Testimonial: " Sounds reasonable. I will check this tomorrow.thanks a lot"
4.0l 6 cylinder. What are the probable causes of DTC P0171?
no. (but the isc valves loves to stick but will not cause black smoke)
the 4.0L is one of 5 million made, it's well known,
the black smoke don't lie. it's rich and the cat seems burned up too.
as with black smoke the cat will try to catalyze all that and glow red hot. is your cat missing?>
so why not believe the code 171, its real and is catastrophic failure. there are 2 engines here, FED and California.(exhaust)
(2 different exhausts and sensors there.
as they say, fix what is OBVIOUSLY bad, 171
(find why using tools or inspections)
Fuel System Lean (Bank 1)in most cases the exhaust is cracked near B1S1 0xy sensor
this causes it to stick at 0volts, (lies) and the PCM sees that obvious lie then goes rich. (limphome rich)
if the pcm cant measure oxygen, it must now guess at fuel trim.(bad that.)
it goes rich, so you dont melt pistons running lean.
(by design)
bad front oxygen sensor (aka , up stream bank 1)
in calif cars, it can have a split exhaust on the I6 and have 3 sensors. (hope not yours, do look..)
most have 2 sensor, front and the useless behind cat sensor(B1s2)
S2 is useless for running mix, the rear is for smog test the cat.
so it rich, and now misfires. and the spark tips are black.
and it misfires to bad it can even idle, sure. (Drops)
the cause, is too rich.
the 171 means the PCM sees it stuck at 0v forEVER.
there are in fact other causes.
but these 2 are top cause.
on all 3 of my 4.0L engines
the exhaust manifold cracked on the under side.
side facing block. (i use a hose to ear to hear the putt putt puts, (with FULL PPE protection from burns from a dead cold engine.) ask how.
even the SST exh. man. did that.
or the header flange gasket is TOAST. (that too putts when bad.)
Aug 03, 2015 | 1996 Jeep Grand Cherokee
Filled up with gas started cutting back and smoke from back of engine
not sure what you are describing really, is it possible you can elaborate? After you filled up this happened? The engine started cutting back? Did you put diesel instead of gas? A common mistake! This will make the vehicle putt putt if it even starts and will have no power what-so-ever! Will just sit there and putt putt. A plugged catalytic converter will get red hot and sometimes hiss if there is any leak you your exhaust and the car will overheat and have a loss of power and the hotter it gets the more the power loss will be until it overheats the head and warps it or blows a head-gasket.
If that is smoke from a fuel leak then this is dangerous of explosion.
If you had a service guy check your oil when you filled up, he left the oil filler cap off and it's spraying all over the exhaust and engine and again dangerous of fire. You must carefully determine what is leaking to cause this smoke, it's either an exhaust leak, an antifreeze (coolant) leak or from the power steering or transmission line or brake line. One thing to find a small leak is to place a piece of cardboard under the engine to see what and where anything is dripping.
Nov 26, 2013 | 1999 Kia Sportage
Lawn Mower putt putt when filter in place
Your air filter screw may be too long from over tightening air cleaner and crushing the cover. It warpes the carb allowing for gas to leak into carb. Grind or cut off screw alittle or put washer on and don't over tighten. thank you for using fixya.
Jun 12, 2013 | Briggs & Stratton Garden
Loses power going uphill
Could be low fuel pressure, or a long list of other things.
Is the check engine light on ?
Does it feel like it is running rough, or starving for fuel ?
Sep 17, 2012 | 1997 Mercury Villager
My truck some times dies on exceleration and ruff ideal than runs fine
I had the same problem with my 93 K2500 it only has 159000 on it. It was my catalytic converter, drop the Y pipe going into your exhaust manifold then drive it. You should feel an immediate difference. You can replace it or cut it open if your state doesn't have emission laws. It cost me around 250 and a couple hours of work.
Aug 03, 2012 | 1993 Chevrolet C/K 2500
It is not getting any gas putt putt putt.
run scanner for trouble codes, some auto parts stores will do this for free
Oct 04, 2009 | 1996 Ford F150 Regular Cab
Mower smoking and sputtering.
Sounds like the engine is getting flooded because the carburetor float needle is not seating. Let me know if this helps.donnyb60
Mar 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
96 Ford windstar GL
If there is white smoke coming out of tail pipe, the head gasket is blown. needs to be replaced.
Jan 27, 2009 | 1998 Ford Windstar
Yard Machines 24A452G700 205cc Briggs  Stratton 800 Series Gas Powered Chipper Shredder () Logo
349 people viewed this question
Top Yard Machines Heavy Machinery Experts
Roland W VanLue
Roland W VanLue
rjivaro
donald boissonneault
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
