Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
I picked up a used craftsman model 358350370 and discovered that the fuel line is broken up. I can see that a line goes to the priming bulb, and one comes from the priming bulb and there are two connections on the carb, but I do not see how the line exits the fuel tank through the hole in the side of the bottom and where it goes. I have three lines which must connect in five places excluding the filter, and only find four connecting points. Help!
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Replacing 16
The second carburetor port feeds the primer (bleeder), returns excess fuel to tank.
Filtered line to carb, carb to bleeder, bleeder to tank (probably not visible and no hose in tank).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
You can find an exploded parts list wit a little detail here:
http://www.searspartsdirect.com/partsdirect/index.action?psid=74199074&sid=PSx20071217x00001a&OVMTC=Exact&site=&creative=3873724584&OVKEY=searspartsdirect%20com
The print is deceptive, it appears the filtered line feed the bleeder it does not!
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 18, 2010
Why does the fuel not stay in the primer bulb, when I prime the craftsman weedeater with sim-pul
Fuel lines probably need replacing. Have you been using ethanol? The alcohol eats the fuel lines on most 2 cycle motors up.
Jul 06, 2014 | Craftsman Convertible 25cc. Gas Line...
Craftsman model 358.797342 leaf blower has two lines going into the fuel tank, one is attached to a filter that lays within the tank, the other line I'm not sure what to do with?
The second line you are asking about is a pressure line that just goes inside the take and when you prime the bulb it puts pressure in the tank it is not attached to anything in the tank only to the primer bulb.
Jan 13, 2013 | Craftsman Garden
Craftsman 33cc weedwacker rep lace fuel lines
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Feb 21, 2012 | Craftsman Garden
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 18, 2012 | Garden
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Craftsman weed trimmer primer bulb is working in reverse
Make sure the line is near the botto ofthe tank.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Jul 19, 2010 | Craftsman 25cc Gas Line Trimmer
Need to know the fuel line routing including the primer bulb.
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Look carefully at the 2 nipples on the carb. You can tell one is slightly larger than the other. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. completing the purge circuit. This info pertains to the Craftsman 32cc with Zama carb and may work on the 25cc model as well.
Jun 01, 2010 | Craftsman 25cc Gas Line Trimmer
When replacing purge bulb on my 32cc craftsman brushwacker I found 3 fuel lines off carb, two were connected to bulb, what's the third? I assume it goes to the other hole on the bottom of my fuel tank but...
the inlet line has the filter on the end in the tank
that goes to the bottom nlet of the carby
the return line goes from under the primer bulb back to the tank
some units run a 3rd line with a filter on the end ( outside of the tank0as that is used to vent the fuel tank as the cap is sealed
the fuel flow is this
through the carby through the pump back to the tank and is only used to prime the float bowl ( needle and seat and diaphragm with fresh fuel and to remove any air in that chamber
Aug 08, 2017 | Craftsman Garden
No gas when you prime it
1) Check fuel lines from tank for cracks, fuel filter in tank, primer bulb for cracks
2)Remove Carburetor
replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 13, 2009 | Craftsman Garden
Craftsman trimmer won't prime
A new carburetor would be simplest solution. You could try disassembling the carb, cleaning and replacing diaphrams, but just replacing the carb would be my choice. What is the model # on the trimmer and I can tell you the part # of the carb you need.
May 24, 2009 | Craftsman 25cc Gas Line Trimmer
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
559 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
