Question about Ryobi Garden
Need to know the diagram for the routing of the gas lines on a ryobi 700r. I replaced the primer balb and the unit does not run, not sure if I have all the lines on correctly. I have switched the lines to the primer and it did not seem to make any difference.
worldvet
  • 859 Answers
SOURCE: Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Posted on Oct 28, 2008
  • 97 Answers
SOURCE: Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Posted on Mar 20, 2009
  • 297 Answers
SOURCE: I REPLACE THE FUEL LINES,NOW IT ACTS LIKE IT WANT TO START,BUT D'
http://outdoordistributors.com/pdf/Ryobi/RYOBI-700r-serials-304051232-thru-.pdf
Have a look at this drawing.
Posted on Apr 18, 2009
  • 8 Answers
SOURCE: ryobi 700r gas trimmer, replace old fuel lines
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
To leemineres, if hoses are on right and unit still stalls after starting initially you probably need to disassemble carb and clean out using spray carb cleaner. May be sticky needle valve, or partially plugged port or jet.Could also be hole in diaphragm. Gasket and diaphragm kit would be good to add when you take apart, even if diaphragm does not have a hole.
Posted on May 20, 2009
  • 8 Answers
SOURCE: replaced new gas line, new primer bulb, new
Have you checked the spark plug?
The primer bulb is broken on my 700r 2-Cycle Gas Trimmer and I would like to replace it
not difficult at all to do , first obtain Ryobi primer /fuel line kit from your local distributor , then remove air cleaner cover (pops off with fingers) then drain all gas from fuel tank back into storage tank , locate the two Phillips head screws next to primer bulb and remove them , careful not to drop them !! remove old bulb from ring and replace with new bulb from pkg. then using a clean cloth , carefully wipe out sealing grove where bulb seats down (I guarantee its dirty) when all clean , place bulb down in grove and make sure it seats well then secure with ring and replace screws (don't over tighten) you might as well replace the fuel lines as they come in kit , instructions are on pkg , I do suggest doing one at a time to not forget how they go , and do use the new fuel filter that's inside pkg too
May 13, 2016 | Ryobi Garden
I need to find out where the fuel lines go for a ryobi 700R weed **** . I bought one at a salebut the fuel lines were gone. Please help. Thanks
This the typical set-up for units in which the primer bulbs are not attached to the carburetor. Walbro carbs.
Sep 13, 2010 | Garden
Gas line hose routing on a ryobi 700r can i get a digram
Check the search feature on this forum for FUEL LINE ROUTING.Much has been written on this popular subject in these forums. Thanks.
Aug 17, 2010 | Ryobi Garden
Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Existing gas line fell aport. Have new hose but need gas line routing for Ryobi leaf blower.
HERE IS THE PARTS BREAKDOWN OF A RYOBI/MTD/RYAN ENGINE.....THE BEST THING I CAN DO WITH OUT PHISICALLY SHOWING YOU. HOPE THIS HELPS AND GOOD LUCK
Nov 23, 2009 | Ryobi Garden
Fails to stay running / primer bulb does not fill
Double check that the fuel lines are routed properly. Another place to look for a potential problem is where the fuel line comes out of the tank. Make sure the hose is not pinched. The typical fuel line routing is the first line (the one with the fuel filter in the end of it) comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb and the third line goes from top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Sep 04, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My ryobi 31cc 15" 700r won't start
You need to push the primer button 10 times or so (the button at the top of the speed control) to get the gass pumped up into the system again. Likely gas not getting through the line yet. Takes awhile.
May 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 700r gas trimmer, replace old fuel lines
Jan 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
283 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
