Question about Dishwashers
We just installed a Fisher & Paykel DD603 dishwasher. Intially it would not drain correctly. And, proceeded to flood the bottom and set off the F1 error code. I dried out the bottom to get the F1 code to stop, which it did. After adjusting the leveling the dishwasher drained both drawers correctly, once. A few minutes after the rinse cycle had finished and the drawers were empty of water the F1 code started again. Now it will not go away unless I unplug the machine. I dried out the bottom very well with a hair dryer and even removed the plastic cover over the flood sensor and dried out everything around the flood sensor. I am having difficulty getting the machine into diagnostic mode. I suspect the lid motors need to be replaced but can't get it into diagnostic mode to check. I followed the instructions in the service manual (press keylock and start/pause at the same time for five seconds) but it doesn't seem to work. Does this mean I need to replace a computer part? Or am I missing some trick? Thank you!
  • j_pickel Jun 05, 2010
    just looking for a second opinion on the problem I am having with my fisher paykel dd603 dishwasher. Thank you!
  • 6,784 Answers
HI. The original code(f1) is in reference to a overfill condition. This may be a clogged drainage Assembly. This condition will usually cause the control sector to short out if not corrected, due to the flood switch malfunction. There are flood switches located on the bottom of each drawer. You will need to inspect the flood switch contacts for oxidation(use a ruby red eraser tip for cleaning the flood switch contacts, if needed). You can also check for proper resistance at the switches, as well. If the flood switch ohms out ok and the contacts are free of oxidation, simply clear any obstruction that can be found in the hoses and pump assembly. Clean the fine particle filter, if needed.
  • NOTE_ Try to reset the main control by shutting down the appropriate circuit breaker for five minutes. Once the five minutes are up, re- introduce power to the unit, and try to initiate a command. If the main control board dose not respond after the hard reset, it will need to be replaced, asap.
Posted on Jun 05, 2010
  • Michael Masters
    Michael Masters Jun 05, 2010
    • Start with the bottom drawer when inspecting the flood switch. Remove the wire harness cover on the underside of the drawer to expose the flood switch. Once the cover is removed, un-clip the wire harness, fill hose, and drain hose. Next, un-clip the linkage at the back of the bottom drawer and lift the
      drawer off the slider arms. This will expose the flood switch, on the left-hand side of the bottom panel. Each switch will have three spade connections and is located under the switch housing.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Although you have already dried out the bottom please once again perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • 1 more comment
    Okay, I followed your instructions and removed the bottom drawer, used a towel to dry up any water although I did not see any and the towel came up dry, I removed the circut board cover, and dried that out (again no visible water), then dried it with a hair dryer for 20 minutes. I then plugged it back in and still got the F1 error and was not able to enter the diagnostic mode. Both drawers have the red lights above the keylock and start/pause button lit up. Both drawers sound like they are trying to start up but the machines keep beeping and will not stop until I unplug it.
    After I removed the circut board cover I noticed that the ground wire had broken off from where it was originally attached. Obviously this will have to be fixed but I am not sure this would cause the perpetually F1 error.
    Any ideas?
    Thank you.
  • Rylee Smith
    Rylee Smith Jun 05, 2010
    I thought
    your issue was resolved earlier this week however, as I said F1 is a flood code
    which means that if any water is sensed under the bottom drawer this unit will
    show the error. To resolve this open the top drawer and check if there is any
    water on top of the divider so that you know if the leak is from top or bottom.
    This can also happen if something is not allowing the lid to close, water inlet
    valve leak, leaking/blocked drain hose and/or the flood switch PCB. Also the
    issue can be caused due to that broken wire. If everything else appears to be
    fine then it can be anything from the main board to the drawer, may be the
    wiring as I said earlier.
    Thanks
    Rylee
  • Rylee Smith
    Still dont think second opinion will provide you a more detailed information then I did.
    Thanks
Fisher paykel cross draining
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Refer
http://www.genuineapplianceparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/?preadd=action&key=WT50
Mar 22, 2014 | Fisher and Paykel Dishwashers
I have a Fisher & Paykel dish drawer model number DD603 and it is not draining. Any tricks?
Hi
Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
Fisher and Paykel Dishwasher DD603 Parts Manual
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
Daniel
Aug 07, 2010 | Fisher and Paykel Dishwashers
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Nov 25, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
The flood switch has been activated on my dishwasher
Remove the bottom drawer by pressing in the tabs on either side of the drawer (bottom edge towards the front).
Dry out the compartment with towels and let air dry.
Apr 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
My f & p dishdrawer model DD603 has fault code F1:
Yes, you need to gain access to the inside bottom panel of the dishdrawer and drain/dry the water in the bottom panel. When all of the water is gone the polystyrene block will lower and turn off the flood system. You then need to find the reason the unit flooded and rectify it or the unit will just do the same thing again.
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Fisher paykel dd603
Pull the bottom drawer out !!!!! To do this on the left and right sides of the bottom drawer you need to pull the pins (Plastic) then pull it out it has hoses still connected pull out and turn on side look in the back left corner (with Pwr off) there is a board there and it has a water (Flood sensor) on it make sure it is dry this is what the Fault code is
Dec 03, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
