Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Convergence I am having problem with my picture.I think that there is convergence issue.I have been told many solutions but don't know where to start.
  • 5 more comments
  • 6425YR Apr 10, 2008
    model#51PW903
    MODEL# 51P9303
  • 6425YR Apr 11, 2008
    my model# is 51PW9303 and the chassie series is dptv 345 would that be the same part? And is there any pictures of this part? Thanks.
I have this same setup, do you know if the stk392-180's will work okay with this?
Posted on Oct 31, 2008
  • 121 Answers
Whats your model number and I should be able to help you out
Posted on Apr 10, 2008
  • dawn garrett
    dawn garrett Apr 10, 2008
    your tv is the dptv 300 series chassis
    your model uses (2) STK392-110 or (2) STK392-120 I recomend you replace with the STK392-120 as they are better ics.
    Also if you order at the website I provided you get free installation instructions plus the option of free instant messaging while doing repair
    http://servicemanuals.vstore.ca/
  • dawn garrett
    dawn garrett Apr 11, 2008
    the dptv chassis 305-355 are all the same...when you look in the back of your tv the board is all the way over on the left hand side thats where the ic's are they are located on large aluminum heat sink on the right hand side of that board.It has lil metal clamps that holds the ic's pop it off and you will see the ic numbers some will have STK392-110 but you should use the STK392-120 instead as they are a better ic
My 55 inch Mitsubishi is 8 years old. when I turn it on the picture is distortedand blury. After about 20 minutes the problem goes away. Can this issue be fixed aon a set of this age or should it be...
IT MAY BE A CONVERGENCE PROBLEM, see some photos and let me know if anything like your problem.
If convergence you will see it better by going into the menu and selecting first convergence, then advanced---this will bring up a grid of lines--should be yellow with no red or blue out of place.
Good news: if this problem it can be a do it yourself repair--I have start to finish, step by step instructions for this repair in this set.
Let me know what you find and I will assist you.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 09, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The picture is out of focus and showing double images in different colors.
If picture looks 3d and will not adjust in the customer menu (convergence) the STK-393-110 this set uses is bad.
This is quite common and the part on EBAY sells for about 15 dollars.
The good news is this can be a do it yourself repair. I have available start to finish, step by step instructions for this repair in this set---takes about 1 hour.
Let me know if you want the instructions and I will get them for you for free.
If this information told you something you did not know or helped you rate this solution as very helpful as I do this here for free.
SD TECH
53556b4.jpgTHIS IS THE PART THAT NEEDS TO BE REPLACED.
Typical convergence problem--no two sets look exactly the same.
12055ae.jpgAnother convergence problem, note colors skewed etc.
Sep 04, 2010 | Mitsubishi WS-55511 55" Rear Projection...
After the set is on for awhile, the picture screen bows really bad and makes you unable to see it. It is a WS-55819 manufactured in November 2001
If picture gets 3d etc, it is convergence problem.
See attached typical photos.
The model indicated uses two of the STK-392-570 chips for this and total parts cost will be under 25 dollars to fix set.
I also have start to finish, step by step instructions for this repair in this model.
If the information or the photos told you something you did not know rate this solution as very helpful as I do this here for free.
No two sets with convergence problem will look exactly the same but you will know if you have the same trouble.
Aug 28, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Sony kp-53hs10 , images have a color out line ,picture is still fare.
IF picture looks 3d in some way it is convergence problem--see attached photo.
Depending on your skill parts cost will be under 25 dollars and I can tell you how to do the repair.
I will also attach photo of typical convergence part---look in your set to see what it uses.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Typical convergence problem, no two look the same.
Typical convergence chip and yours will have two, all have a STK number printed on the front of them.
If you have questions, comment here and I will assist you.
SD TECH
Aug 26, 2010 | Sony KP-53HS30 53" Rear Projection...
The colors are all there but there is a double image. Like a blue or yellow outline around everything and words are doubled. I think it is a convergence problem but I don't know how to fix. Please help.
It is convergence problem---set uses either 2 or 3 chips for this (most use two of the STK-392-110 OR 150 CHIPS.
Total parts cost on EBAY would be under 25 dollars.
This can be a do it yourself job if you can solder and have some skill.
See attached photo of convergence problem and typical convergence IC.
If this told you something you did not know, rate this solution as I do this here for free.
SD TECH
Aug 24, 2010 | Hitachi 60DX10B 60" Rear Projection...
Picture doubling like convergence problem?
If you go into the customer menu with the Mitsubishi remote and red or blue are skewed and will not move in some direction---it is a convergence problem.
The model indicated uses 2 of the STK-392-570 convergence chips.
A pair of the chips are available on EBAY FOR ABOUT 14 dollars.
The middle circuit board in the set has to be removed for replacement but I have start to finish, step by step instructions for this repair in this model.
They are based on my own experience at doing this repair in these sets hundreds of times.
They tell you everything you will need and exactly how to do the repair from start to finish.
Let me know if you want the instructions by posting a comment to this solution.
If this information told you something you did not know rate this solution as very helpful as I do this here for free----I am here to help.
REGARDS, SD TECH
Aug 12, 2010 | Mitsubishi WS-65807 65" Rear Projection...
The convergence red and green colors are bleeding into the picture. On the bottom of the screen and on the left side of the screen. I tried to readjust the convergence factory settings and the problem...
Hi
Thanks for using FixYa.This is often caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are
repair kitsavailable which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
Color poor, essentially black & white
Hi
Thanks for using FixYa. This issue is caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. Please also check the convergence board for cracked solder. If you want to do the repair yourself there are repair kits available which includes instructions on how to replace them. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | Philips 50P8341 50" Rear Projection...
I have a 4 year old RCA Model # HD52W59 HDTV that just developed a convergence problem. Besides seeing all three colors the picture bow's inward on both the top & bottom of the picture. When you...
Hi
Thanks for using FixYa. This is often caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are
repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 18, 2010 | RCA HD52W59 HDTV Projection Television
PT-53wx53g Convergence issue?
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 02, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
320 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
