Question about Whirlpool LSB6200KQ Top Load Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
    New Friend:
My washer machine bowl keeps tilting when washing?
Posted on Apr 04, 2015
    New Friend:
It's most likely the lid interlock switch. Remove the 2 screws above the slot for the switch. Carefully work the switch out through the opening between the housing and the agitator holder. Squeeze the switch back together and secure it with a zip tie. Reassemble.
Posted on Jul 07, 2013
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Posted on Nov 13, 2010
  • dena mcgee
    dena mcgee Jun 01, 2015
    Did you find out what the problem was that's my exact problem.
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Whirlpool heavy duty super capacity plus washer will not agitate or spin. I replaced the agitator dogs but still have the same problem, is this a transmission issue?
Your model may have a flexible (break able) drive component between the motor and the transmission. Check that, it is a pretty easy replacement.
Jan 22, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSB6200KQ Top Load Washer Logo
2,951 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
