Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Tractor stalls i start mowing after 15 min. or so it stalls. Let cool down then its runs again for 15 and stalls.
    New Friend:
I had a similar problem with my Craftsman 42" lawn tractor with a Briggs and Stratton 17 HP engine. The problem turned out to be the solenoid valve on the bottom of the carburator. The valve shuts off the gas when you turn off the mower to stop backfire. After I replaced the valve, the mower is working like new.
Posted on Jun 01, 2013
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
When it stalls, does it die suddenly, as if you turned off the ignition? If so, there may be an electrical problem. Heat causes plastic circuit boards and connectors to expand, and if there's a crack it could open a circuit. One way to find it -- get a can of circuit chiller spray (like this). Run the tractor until it's hot, and stalls. Now spray various ignition parts, one-by-one, testing the tractor after each spray. I'd try the ignition switch, the relays, and the connectors around those. If it seems to fix it, repeat the experiment to be sure. Then replace the bad part.
If it stalls gradually, like it's being dragged down, then it could be mechanical friction - like a bearing or shaft that's heating up and expanding. If you drive around without the blades on, does this still happen? If so, that eliminates the mower deck with its spindles and pulleys as a cause, and suggests it could be the engine. Good luck!
Posted on Jun 05, 2010
2000 suzuki vitara runs 15 min stalls wont start till cools down
Did they figure out if you are loosing fuel or spark when it fails to start up ? You would need to know which to proceed.
Feb 13, 2014 | Suzuki Grand Vitara Cars & Trucks
Craftsman lawn tractor model no.917.289101 stalls out
Stall or quits? Will it run 15 minutes again after it cools down. Check
carb bowl for water. Loosen the bottom screw a little until gas come out and water will "roll" off the gas that drops out on the deck.
May 21, 2012 | Craftsman Garden
MY ******* WILL SHUT DOWN AFTER ABOUT 30 MIN OF MOWING LET COOL OFF ABOUT15 MIN WILL START WRIGHT BACK UP AND MOW AND WILL DO IT AGAIN CAN YOU HELP ME
You have a Ignition Coil (Module) going bad. This is how they act right before they quit completely. You may be able to pick one up used pretty cheap from a small engine shop.
Good Luck!
Jim
Aug 10, 2011 | Garden
2010 model 20 hp Briggs motor. Fuel going through fuel line, but not going into carberator. Motor runs good for about 15 min, but after heating up this fuel problem starts. After cooling down for an...
Two things:
1 Is fuel coming out of the fuel line. Older mowers have old fuel lines and they tend to get weak and collapse went they warm up with engine heat. Replace the old fuel line.
2 deposits in the carb. take off the air cleaner, start it up and spray a good carb cleaner in the carb until the engine dies. Put some 'seafoam' in the gas and a little in the oil and put the air cleaner back on and start the mower and mow on FULL THROTTLE. this should claen out the carb. Yes the mower will run rough for awhile.
these two cheap fixes will solve 85 % of carb problems. GOOD LUCK
Jul 17, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 16.5hp 42 in. Mower runs for about
mine always starts-- and won't start again if I turn it off- going to try the flywheel key replacement-- which affects the timing-- otherwise-- let me know what you find out as a solution
May 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stalls when hot
it is overheating. first thing to try is ****** the timing, to run cooler, as you have just replaced the points.-plz rate -bozcro
Sep 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cuts out and then quits. In about 10-15 min. will start again.
I think that cooling off is doing it,I think your gas is filling you carb bowl,remove you carb and take bowl off ,I would buy a kit,I have had problem with the floats sticking or have been damaged by water freezeing,that carb is easy to rebuid you will do good and you will have the pride of fixing it ,good luck and thanks
Jul 28, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Engine stops after ~ 15 - 20 min of mowing
try changing the spark plugs. if that doesnt work check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes.
Nov 05, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
510 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
