Question about Craftsman Garden
Sears e-z start weed trimmer, will not start
Sears e-z start weed trimmer, new gas and oil, new plug. Seems to be no spark.
SOURCE: Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
Posted on May 28, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Stihl FS 110 brush cutter loop trimmer
Check the fuel filter, you are not getting fuel so therefore the spark is not getting anything. You can also take some carb cleaner and clean your carb. This is a common carb issue and it needs either a new filter(recommend) and also some carb cleaner shot through the system
Posted on May 18, 2009
  • 4 Answers
SOURCE: Weed wacker wont start
You do know my neighbor took her sears craftsman edger in and got a new one after a year. TAKE IT BACK!!!!!!!!
Posted on Jun 09, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a gas trimmer. It starts but will not stay
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 11, 2010
hunter19_46m
  • 7482 Answers
SOURCE: ryobi trimmer model ry34420,starts,but stops when
Hi waynedavis50...
Yes a 10% Ethanol fuel can have some adverse effects on certain carburetor parts.
It can cause your "0" rings to grow and close off vital fuel passages and also cause them to start disolving and can plug passages.
You may need to rebuild your carburetor, try what I suggest below.
Check your fuel filter if you have one, normally they are located in the fuel tank.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on May 12, 2011
Testimonial: "thanks,this is a newly rebuilt engine,what do they do when they rebuild?"
I have a Ryobi 430 4 stroke weed wacker try to start this morning seems like it was frozen up took spark plug out pull the string free flow rotates easy put spark plug back in very hard to start fraid I'm...
Paul you might want to replace the spark plug, make sure the gap on the plug is correct, make sure there is oil in the machine, some have a safety switch when the oil is low. If you cant buy a new spark plug you can sand off the tip that is probably black and replace it in the machine
Nov 28, 2014 | Garden
Craftsman 32cc gas trimmer won't start.
Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
Gas weed trimer will not stay running/clean gas lines/new fuel gas fillter/new gas/oil
Try checking the sparkplug wire. They sometimes get loose and don't make good contact. Clean the contact, if it is corroded, clean with a wire brush. The Spark plug may need to be replaced, be sure a new spark plug has the right gap size (you can adjust that yourself). Beyond that, I would take it in for servicing.
If it still does not keep running, check for leaking lines. If there are air leaks around the carborator, it will run rough and not for long. Hope that helps.
May 02, 2012 | Garden
I have a craftsman 32cc weedwhacker trimmer and its brand new and it hasnt started from day one it isnt getting any spark at all
If you have spark problems, remove the wire and then remove the plug, reattach the wire and ground the plug to the engine and pull the string, you should see arc and hear it pop, if not, take the plug to another piece of equipment and remove that equipment's plug wire and attach it to the plug from the weed ******* and then ground it and test it. If still no spark, then plug bad, if plug then the weed ******* has a problem with the spark plug wire or the ignition coil.
If you have spark at first test, then the problem with the weed ******* is somewhere else.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
CRAFTSMAN WEEDWACKER 316-791860, WILL NOT START. HAS SPARK, FUEL LINES FILL UP, WAS RUNNING FINE, DIED, STARTED NEXT AM, RAN 5 MINS THEN DIED AND WOULDN'T RESTART
Two things which may be the problem: 1) carb need to be rebuilt or replaced, and 2) you need a new spark plug. The carb with shipping is around $50.00 from sears ( http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-3167918602008/0247/1503820/P0805032/00001?blt=06&prst=&shdMod= ) A sparkplug can be had at any small engine repair shop and most auto parts stores for less than $5.00 Start with the cheap solution... Also make certain you have fresh gas and that the oil mix is correct.
Apr 07, 2011 | Craftsman Convertible 25cc. Gas Line...
Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
My weedeater brand trimmer won't start
I believe you have the wrong GAS AND OIL MIXTURE. MOST WEED EATERS are a Ration of 90:1 or even less 75:1 For WEEDEATER I would use a 50:1 or if you choose 32:1 should work. Use a good 2-stroke oil. DO NOT USE ANY OTHER OIL> You see the more oil you use the harder it is to start. Don't forget to Pump the fuel Bulb on the side before trying to start it.About 3 x should do it. GOOD LUCK and it is and does effect me when their is death by a LOVED ONE. My prayers are with you! From Mddoc13 ( BOB)
Aug 28, 2009 | Craftsman 25cc Gas Line Trimmer
Jun 09, 2009 | Craftsman 25cc Gas Line Trimmer
My te 475 weed eater wont start
Check the on-off switch? Try disconnecting the switch and see if it starts. If it does, replace the switch.
May 18, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Garden Logo
67 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
