Question about Hayward 100kbtu Pool Or Spa Propane Gas Heater H100idp1
The heater works fine except for a whining sound while the inducer motor is running. This sound is much more pronounced than it was when the unit was first installed about 4 months ago. This is for an Hayward H100IDP1 spa heater.
SOURCE: Hayward H300 Spa Heater will not fire up
try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
Posted on Jun 13, 2009
  • 246 Answers
SOURCE: Hayward H100IDP1 steeming pipe
english is good th epipe taking the steem out has a reason to be may be the heater is over heating or is has been left open by accident but here go if open may the heater exchanger is plug the pipe has been installed reverse or assembly valve is not good any more , is the flow to slow? psi at the filter must 10-18
Posted on Sep 14, 2009
  • 990 Answers
SOURCE: Fixing our hotel's Hayward CSPAXI55 spa heater.
You can probally get a manuel on line if you go through Hayward.
When he took the old one out he probally just wired the circut together where the temp assembly goes into the cabnet in the top right front of cabnet in the upper panel. Then the temp probe runs around the side to the water header or manifold. If this is in the orignal spot it is on the right of the heater and easy to find. I'm not sure but if the exchanger has been turned then it will be around the back side of the header and it will be on the left side of the heater. Geting a manuel for this is a good idea anyway, good luck.
Posted on May 09, 2010
  • 64 Answers
SOURCE: H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1: how do i fix the AO code on my hayward heater?...
AO will apply to your blower, blower tubing, or blower vacuum switch. You need to check these items.
Posted on May 20, 2010
  • 760 Answers
SOURCE: ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Posted on Jul 29, 2010
Have an older Coleman mobile home furnace (Mdl 8665D766). Both blower fan and booster motor work fine; however, during heating, booster motor will keep constantly running after system cycles through
The booster motor? Do you mean the inducer motor that helps push the exhaust? If the inducer motor won't shut off when the thermostat is satisfied and everything else does shut off, it sounds like the contacts on the relay that powers the inducer are at fault
Feb 03, 2018 | Coleman Heating & Cooling
I am working on a m/n 58SS080-bc carrier the .When a call for heat the inducer motor didn't come on replace the control board for the inducer motor and it still didn't come on .Icheck for the low voltage...
hi there,
is there an inverter board or a thermocouple in this unit? sounds like you have too much voltage coming to the board. can you measure the voltage to the motor?
Oct 02, 2008 | Carrier Heating & Cooling
2 flashes wont light
SOUNDS LIKE A PRESSURE SWITCH MALFUNCTION OR A OBSTRUCTED FLUE EXHAUST. 2 FLASHES MEANS YOU ARE IN SYSTEM LOCKOUT. ATTEMPT TO START 3 TIMES THEN IN LOCKOUT MODE RIGHT? YOU WILL NEED TO TURN OFF AT T-STAT OR BREAKER TO RE-SET UNIT, OR WAIT 60 MINUTES & IT WILL DO IT AUTOMATICALLY. WHEN IT CALLS FOR HEAT THE DRAFT INDUCER MOTOR WILL COME ON, THIS WILL CREATE A VACCUM THAT OPENS THE PRESSURE SWITCH PROVING DRAFT INDUCER IS VENTING, THE VACCUM CREATED CAUSES THE PRESSURE SWITCH TO OPEN PROVIDING POWER TO THE IGNITION CONTROL. THIS IS WHERE YOUR PROBLEM IS ACCORDING TO YOUR DISCRIPTION. TRY TO DISCONNECT VACCUM LINE FROM DRAFT INDUCER MOTOR & SUCK ON IT WHILE LISTENING FOR A CLICKING SOUND AT PRESSURE SWITCH. IF YOU DON\'T HEAR THE CLICKING SOUND WHEN YOU DO THIS, THEN YOU NEED TO REPLACE THE PRESSURE SWITCH. IF YOU DO HEAR THE CLICKING SOUND THE PROBLEM IS WITH AN OBSTRUCTION IN THE FLUE VENTING. THIS IS SOMETIMES CAUSED BY DEBRIS GETTING LODGED IN THE PORT AT INDUCER MOTOR WHERE THE VACCUM LINE FROM PRESSURE SWITCH IS CONNECTED. TRY TO CLEAR OBSTRUCTION WITH COMPRESSED AIR OR A WIRE HANGER. THIS SHOULD FIX YOUR PROBLEM. GOOD LUCK. HOPE THIS WAS HELPFUL.
Dec 24, 2012 | Mr. Heater MHU45NG
I replaced the combustion inducer motor the new motor runs slow and does not produce enough pressure could something on the board be bad?
Could be. what is the voltage going to the inducer? You might have a bad ground or a polarity problem. Let me know what voltage you have and we will go from there. Does the main blower motor run fine?
Dec 30, 2010 | Goodman GMS90703BXA Heater
It seems the bearings on my Induced Draft Blower Motor are going out. The furnace runs for a bit then I can hear the motor seizing. It has been making whining noise for awhile but has gotten...
While you may be able to get just a motor it will not save you much. You will also run the risk of damage to the housing or fan(s) when you take the old one apart and try to install a new motor. Unless the new blower unit is several hundred dollars I would recommend you replace the whole assembly.
John
Dec 02, 2010 | Goodman B1859005 Induced Draft Blower...
Have a Goodman GPG13 single package gas-electric heating and cooling unit. Turned on the heat and the outside unit ran a short time then shut off. Smelled gas after it shut off. Is this an igniter...
There is a induced draft motor that will run first to purge the combustion chamber and induce a draft, a pressure switch closes proving an induced draft exists, thus allowing the spark and pilot gas, or hot surface ignitir and gas to pilot rsil and /or burners, a trial period for ignition about 30 seconds each for 3 attempts will be made and if not lit by the 3rd attempt it locks out, requiring a reset of power to unit to reset the module or circuit board etc. 1st see what motors running, is it the flue exhaust motor/induced draft??
Nov 02, 2010 | Goodman Heating & Cooling
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
Weird sound coming out of the rotary unit inside gas heater
It may be your inducer motor making the noise. If there are any hoses hooked to the housing, make sure they are clear of blockage and moisture. Look for any way to drip a few drops of oil onto the motor shaft, it may help. If the unit is more than 10 years old, you might as well change the inducer motor as a precaution. It will fail at a most inconvenient time anyway.
Dec 23, 2009 | Goodman GMS90703BXA Heater
I have a central heater. it will come on and worh fine, by this i mean the draft induce motor comes on, then the glow igniter will come on then flame will come on but after 10 minits or so it will stip the...
sounds like the filter inside of the unit may be dirty and or the vent cap could be partially blocked causing the flue gas to build upo until the unit tripos on the high limit saftey
Dec 16, 2008 | Heating & Cooling
Hayward 100kbtu Pool Or Spa Propane Gas Heater H100idp1 Logo
102 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
