Question about RCA R52WH73 Projection Television
Convergence Quit Convergence not working, no Convergence option on menus
  • RCA Master
  • 3,459 Answers
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence Quit - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 06, 2010
Convergence test
There is a convergence disk that you can order from companies and use it in place of on screen or missing divergence programs.
Feb 21, 2014 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Audio but only black screen for video on WS65807
First, the set has a hard reset but it will NOT affect convergence which is stored in a separate area of the set.
Model indicated has 3 hidden menus---all accessed with the Original remote and a 4 digit code.
At your own risk:
This is a V17 chassis that was used in 8 models.
It has 3 hidden tech menus: With set on:
Option menu is 8270 enter---The Option menu reset will return all settings to factory and also will clear any glitches out of the way--it as stated can cause Convergence not to be affected.
Circuit adjust menu: (stay out as one wrong move and fatal things can happen is : 8257 enter.
Convergence adjust menu: (better than customer and SAVES adjustments made in to the DCU or digital convergence unit in the set.
I STRONGLY SUGGEST YOU TRY THE OPTION MENU FIRST, IF NEED DETAILED INSTRUCTIONS I CAN LOCATE THEM FOR STEP BY STEP OF THAT.
SEE IF IT CLEARS THE MAIN ISSUES UP FIRST---IF YOU TRIED TO ADJUST CONVERGENCE IT MAY NOW BE MESSED UP BUT UNLESS YOU GET THE SET BACK TO WORKING SOMEWHAT NORMAL NOTHING TO WORRY ABOUT.
keep in mind I do this here for free and have worked on hundreds of these Mitsubishi sets.
SD TECH------ASK BEFORE YOU LEAP!
Dec 02, 2012 | Mitsubishi WS-65807 65" Rear Projection...
Resetting eeprom
These sets including this one have 3 hidden menus---OPTION menu which allows a hard reset of everything except the convergence, Adjustment menu--be careful in there, and Convergence menu which adjusts better than customer one and saves better.
Each is accessed with a four number code using the Mitsubishi remote.
I have a list of most of the codes available.
Nov 07, 2012 | Mitsubishi Televison & Video
How do I reset my Mitsubishi WS-65908
Model number here has 3 hidden menus--adjustment (keep out of that one) and convergence, and OPTION menu.
In the Option menu with the Mitsubishi remote you can do a hard reset of entire set--sets everything back to factory except convergence adjustments.
This requires the Mitsubishi remote and a 4 digit number code.
I am willing to give that but first would like to know WHY you wish to do that as it will not cure all problems like dead set, convergence etc.
Apr 16, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS55315 rear-projection has gone dark
Yes, they have other than convergence circuit problems----very few issues or troubles.
You should test the shops by asking if they have the 4 digit code number for this model for the OPTION MENU---set has 3 hidden menus and OPTION menu will allow a hard reset of entire set---the other two menus are adjustment and convergence menus.
If some shop has no idea what the option menu is----pass them.
Mar 24, 2012 | Mitsubishi WS-65315 65" Rear Projection...
The blue,red and green colors need to be aligned but i cannot find the option in the menus. I Had to do it once but i cannot find the option now
Very common problen caused when the fL231 and DL231 blow it makes the option disappear from the setup menu. You can get the repair kit called the ITC222 and ITC222a convergence option missing repair kit from www.tvrepairworld.com which contains the parts and the CD with instructiions.
Jul 18, 2010 | RCA HD52W59 HDTV Projection Television
The picture is on a slant. I haven't got a manual as it was second hand. I have the remote but I cant work out how to change the picture settings
It is possible that in the menus there is a setup that has picture rotation. But for this model, I believe there is no rotation option. You will have to go through the menus to see if it is there. I would start in the video, or the picture setup menus. Press menu on the remote to go in to the menu. Use the arrow buttons to move through the menus.
If there is no rotation option, this means the deflection yoke has been turned or was never strait from the manufacture. Yoke rotation is not something I would advise for you do yourself. If you rotate the yoke, there is the possibility the set will require a complete re-convergence and purity setup. You will have to have the training, and the required pattern generator to perform these adjustments.
You could call an experienced TV service man, especially someone who has a lot of experience working on Sony. This type of tech should know what to do to fix your problem.
Jerry G.
Nov 14, 2009 | Philips 28PW8608 28" TV
Pt5499hd wont focus separation of color on left side of screen
have you tried adjusting the convergence?
just in case, go into the menus, go down a few options and convergence is above the vchip option. go between all the crosses and line them all back up. if you cant move them, or you can move one and not the other, than your convergence ic's are most likely the culprit.
Aug 04, 2009 | Akai PTH5498 54" Rear Projection...
Convergence problem
I have a VS-45607 and If the VS-5052 has the same menus then there are two options for convergence. One is the basic convergence where there is one set of crosshairs and you line them up. Then there should be an option for "advanced" calibration where the whole screen looks like a grid and you go to un-converged crosshairs and align the screen. Most likely not all of them will need to be adjusted, but for me, the lower right hand corner wasn't aligned right and this cleared it right up.Good luck
Dec 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Colors Misalinged
You have what is known as covergence problems. Ok to begin with. 1 Go into customer menus goto SETUP do you have the "CONVERGENCE" option. If you do not the the likelyhood is you have the fl231 fuse problem and if you can solder and get it i recomend it a simple repair. ok if you have that option then try going in and autoconvergening if that didnt work try manual the red and blue convergence. if in the manual red and blue the crosshair didnt move then you probably have convergence power board problem if only one moved or just move a up and down or left of right then it might be a amp board issue. the other problems it could need a simple factory alignment.
Aug 26, 2008 | RCA HD56W66 56" HDTV
RCA R52WH73 Projection Television Logo
186 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
