Question about Casio FX-7400G Plus Calculator
How to change the radyon to degree - Casio FX-7400G Plus Calculator
  • Casio Master
  • 7,993 Answers
Turn calculator ON
If you see no icons, press the MENU button
Use the navigation keys to bring focus on the RUN icon and press ENTER/EXE.
Press SHIFT MENU to access the (SETUP) screen.
Highlight the line ANGLE.
IN the bottom of the screen you see tabs.
Press the one that is under DEGREE.
See screen capture
Posted on Jul 25, 2010
How to change the temp. from F to C
C = [(F - 32) * 5] / 9
7.March.2015
Mar 07, 2015 | Measuring Tools & Sensors
Tip
Changing brake fluid
ATE currently produces and markets two DOT4 brake fluids with the identical specifications: * Dry boiling point of 536 degrees Farenheit which is 122 degrees Farenheit above DOT4 Specifications, which is Super Racing Blue * Wet boiling point of 392 degrees Farenheit which is 113 degrees Farenheit above DOT4 Specifications, which is Original Brake Fluid TVP 200. Other than packaging, the primary difference between the two is color. The Blue is blue in color and the 200 is clear or light amber in color. This facilitates flushing and changing fluid such that if used alternately, the flusher will know that the job is done correctly when the color change is complete.
on May 19, 2008 | 2007 BMW 760Li Sedan
How do I change the temperature display on a Digitech XC-0366 weather station from Degrees F to Degrees C?
Pressing the - (minus) button on the back toggles temperature units. Pressing + (plus) toggles barometric pressure units.
Feb 26, 2015 | Measuring Tools & Sensors
Change from farenheit to celcius
1 degree C = 1.8 degree F.
0 degree C = 32 degree F.
100 degree C = 212 degree F.
Oct 15, 2014 | Cars & Trucks
I have just rebuild my 2002 kx250 top and bottom but the mechanic wants me to get the timing degree ? i know it has 3 marks on the stator
What the mechanic is talking about is the degree of the camshaft gear to the crankshaft. The easiest way to do this is with a degree wheel, but the timing degree should not have changed during rebuild and is pretty hairy to change manually. The marks on the flywheel are degree marks, and there should be 1 timing mark. You will have to find out from a kawasaki dealer which mark to use for correct timing. Hope this is what you were needing, Daniel.
Nov 09, 2011 | Motorcycles
MY OVEN IS VIKING OVEN CAN YOU PLEASE TELL ME HOW TO CHANGE FARENHEIT FROM CELCIUS
Hi and welcome to FixYa, I am Kelly.
Here is how you change it:
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
scale.
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Kelly
Mar 22, 2011 | Microwave Ovens
When i change the temperature to make it hotter, the screen blinks then goes back to being 30 degrees colder. Is my heater ignoring my request because it never reaches the temperature i want it to. it...
First you have to understand in thermostat there are Fahrenheit & Centigrade degree. If Centigrade between 16 to 30 and if it is Fahrenheit 60 to 86.
If you press the symbol ther> and > (or) ther- and ther+ at a time degree will change.
Now you set your temp +10 degree from your room temp and also keep "heat" mode.
Dec 14, 2010 | Heating & Cooling
How many qrt of motor oil do i need to use
1996 Isuzu Truck Trooper 3.2L MFI SOHC 6cyl
The Engine Oil Capacity 5 7/10 Quarts (including filter)
Engine Oil Type and Weight
Oil for use in temperatures ranging from -13 to 100 degrees
5
Application:
Note :
Quarts without filter change
Oil for use in temperatures ranging from 32 to 100 degrees
5
Application:
Note :
VALHD30
Application:
Note :
Valvoline Premium Conventional 30 Motor Oil
Hope this help (remember rated and comment this). Good luck.
Mar 29, 2010 | 1996 Isuzu Trooper
Casio FX-7400G Plus Calculator Logo
153 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
