Question about Dell Dimension 4600 PC Desktop
Computer that keeps saying F1 to reboot F2 for setup utility
Got the computer from someone else and just turned on.
  • 128 Answers
What is the message you getting?
if it is to press F1 key to contiune then u need to replace ur cmos battery. you will find the battery on ur mother board, if there is no battery then you need to buy a new battery .
good day
Posted on Jun 05, 2010
Selected bootdevice not available - strile f1 to reboot, f2 for setup utility
Hi samuel nyama...
Tap on the key F2 and go into the set up utility...when you are in there pick to boot from the hard drive...click to keep the changes then click to exit...
Please take time to rate me
Sep 17, 2011 | Dell OptiPlex GX620 PC Desktop
My Dell Dimension 5100 desktop wont boot up, it starts the DELL sequence but then messages with F1 reboot or F2 setup Utility. I have recently had to revert my pc back to factory settings and restore...
thegreensx4
It does sound there is a problem with the hard drive. However if you hit F12 at boot you will get an option to run the system diag on the computer. Let me know the error you get and I can tell you where the problem is.
Issken
http://www.fixya.com/users/issken
Jan 13, 2011 | Dell Dimension 4300 PC Desktop
My Desktop Dell Optiplex GX200 computer says Alert! Cover was previously removed. Strike F1 to retry boot . F2 for setup utility. I never opened my computer and when I click F1 it doesn't do anything but...
If it is not keeping time then you need to replace the computers clock battery. The battery is a cr2032 battery usually.
follow the below link for instructions on how to do that.
http://support.dell.com/support/edocs/systems/opgx200/en/sm/index.htm
Sep 01, 2010 | Dell OptiPlex GX200 PC Desktop
My Dell desktop computer is plugged into a master switch. But I still have to turn on the computer to use it. Lately when I turn on the master switch, the computer turns on automatically. But the Windows...
Press F2 to enter the system setup. Someone or something (Bad Motherboard battery most likely) has reset the BIOS defaults, which includes the Floppy diskette drive controller to be ON. Set Diskette Drive to NONE, then under integrated Devices, set diskette controller to off, save settings and reboot
(ALT + B)
if issue re-occurs then the watch battery on motherboard is bad and needs to be replaced
Jul 16, 2010 | Dell Dimension 3000® Pentium® 4...
Problem rebooting Dell PowerEdge Server 2600
ERROR 02A2: BMC System Error Log (SEL) Full
press F1 to continue or F10 to enter BIOS.
I wait for 2 minutes without doing any thing my server get started normally.
Please help me how to stop this error
Feb 19, 2010 | Dell PowerEdge 2650 Server
Everytime we boot up our computer it says press f1 to do something and f2 to enter setup mode?
generally an indication that something is wrong in the system setup. Press F2 and enter setup, check the time and date settings and the system event log (If BIOS has one) for incorrect settings, also check and see if the BIOS shows a hard drive installed.
If time and are wrong, set them to correct and save settings. If system keeps losing time and date after power is removed, then the backup battery may need to be replaced.
If HDD is not detected, then reseat it. If still not detected replace it.
Dec 10, 2009 | Dell Inspiron 600m 1.6GHz Pentium M...
RAM installation
Hi hunter555,
First off, you've done a lot of work for nothing. What you need to do is put back the new memory. When the Dell Bios boots, it confirming that it has detected the new memory. What you need to do is hit the F1 key to reboot and continue on to the XP installation. When you open the case, it will say the same thing. Don't worry about it, it's only confirming that the case was opened. Typically, I shut off the case intrusion detection, only because I'm always adding things to the machines and it's just a extra step I have to take to boot. However, it's good to know that your bios is confirming that you've opened the case, and that you've put in new memory. You want to make sure that the setup recongizes the entire memory in the banks. So, go to the system information page and make sure that it's reading the original and the additional memory 256k you added. Otherwise your done.
Good Luck
Mark
Jan 14, 2009 | Dell Optiplex GX150 Tower Computer - 1GHz...
I've installed a new hard drive and put in more RAM on my Desktop. Now i get this message WHAT DO I DO. The amount of system memory has changed. Primary hard disk drive 1 not found Strike the F1 key to...
Strike F2 to go to the bios to run the setup utility
Don't touch anything , save and reboot
If primary hard disk still not found
reboot press F2 to re-enter the bios
Look for Auto Detect Hard Disks
if the computer shows a hard drive is detected
set the drive to LBA if possible
save and reboot
Az.
Sep 15, 2008 | Computers & Internet
My Dimension 4600 won't boot
strike F2 for setup utility and then find there "use default configuration or default optimized configuration" (something like that" then press F10 to save and exit.
Don't work?
Replace the CMO battery and then do the above statement.
Dec 21, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
98 people viewed this question
Alun Cox
