Question about Roxio Easy VHS to DVD for PC
When i insert the cd after i am promted to, get a failed message
I inserted the roxio device into the USB port, got a promt to insert the CD, message appeared stating windows couldnt find the software
  • 128 Answers
When you connect any device to your computer , you need to install the driver for that device, drivers are given with the device on a cd, you need to install the cd first , to be able to use your device.
good day
Posted on Jun 05, 2010
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
After inserting CD set up disk , it promts me to take cd out restart computer and try to reload set up disk , over & over!
You should not have to restart your computer to install router. try downloading the installation file from the d-link website :)
Dec 27, 2010 | D-Link DIR-615 Wireless Router
Windows Not Recognizing Device
Insert your operating system disc in to your cd/dvd rom drive, then go to my computer properties, now go to device manager and right click on keyboard or mouse what you want, now re-install your device from your cd/dvd rom, and restart your system.
Jun 04, 2010 | Logitech Wireless Access Duo Optical...
I CANT FORMAT MY MEMORY CARD....I DONT KNOW HOW TO FIX IT.
  1. Open control panel.
  2. Open administrative tools.
  3. Open Computer management.
  4. In the left column click disk management.
  5. This populate all the disk present
  6. Locate your memory card
  7. Then you can delete the partition entire and build new one
  8. You can format with Fat Or FAT32 file system
  9. Do not perform quick format.
Another options are available to format via cmd
To do that
At the run Menu type:CMD
then a command promt window will open
Type format x: /fs:fat32
Note that x is volume label (memory card drive label may d, e or f)
ok
try this
Feb 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
How I install the printer to my PC?
if you have a new printer connect the cable of the printer to your cpu, power on then the comp. will promt you or ask you about the installation disc of the printer, all brand new printers have this, then insert the disc to your cd/dvd rom drive it will automatically run then install it just follow the step by step instruction given to you while you are installing the device
Nov 30, 2009 | Lexmark X5150 All-In-One InkJet Printer
Why does computer asks insert a correct dvd or cd rom
if you have loded and the game came on two disk make sure the correct on is in the drive you need the disc to run game
Jul 31, 2009 | Codemasters Heroes of the Pacific
Cd rom drive not able read data cd
First Go to control panel- System icon- Hardware Tab- Device manager
Expand the CD/DVD roms- Right click on your CD/DVD drive and Uninstall it.
Now download the utility from the following link and just run it on your system.
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
It will take a quick minute to run this utility.
After this restart your computer. It should work fine
Feb 04, 2009 | Sony VAIO VGN-FS640W Notebook
Command promt not openin
You may try rebooting your computer to Safe mode w/networking. Try your command prompt in safe mode with networking. Download and run the program on the link. This would fix the registry of your system.
http://tinyurl.com/4paxty
You need to run the registry checker on this application as well. You will have the option to fix the corrupted registry..
If you can access the command prompt. Insert your windows XP or VISTa cd then on the command prompt. run this command
sfc /scannow
Restart your computer.
Kind regards,
Jeff
Oct 16, 2008 | HP Compaq Presario 2200 Notebook
Play cd's on my dvd
put cd in tray and let it load-then go to menu and hit button that says-play audio CD-your DVD player should also promt you when the cd is inserted with instructions for your peticular model
Dec 19, 2007 | Televison & Video
Roxio Easy VHS to DVD for PC Logo
121 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
