Question about Apple iPod shuffle MP3 Player
How to use an ipod shuffle charge
I cant ever use the ipod after charging it and turning it off then turn it back on the next day like it doesnt hold a charge or maybe since it doesnt have a screen im not using it right but i think i got ripped off i got it from a dude off of craigslist and it is wack
  • soniflore Jun 05, 2010
    i want driver for ipod aple no A1199
  • 600 Answers
Use iPod Reset Utility to restore the following iPod models back to their factory settings when iTunes is unable to do so. The process completely erases all music and data and reinstalls the iPod software version listed below:
  • iPod shuffle (1st generation) - iPod Software version 1.1.5
  • iPod shuffle (2nd generation) - iPod Software version 1.0.4
download here
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
then install..
follow these instructions..
Using iPod Reset Utility
  1. Quit all running applications on your computer.
  2. Open iPod Reset Utility.
  3. Connect iPod to a USB port on your computer. Do not connect iPod to a USB port on your keyboard, or other non-powered USB hub.
  4. Click the Reset button.
  5. If prompted, enter an administrator name and password. Notice: Do not disconnect iPod during the reset process.
  6. When complete, quit iPod Reset Utility and open iTunes to load music onto iPod.
Posted on Jun 06, 2010
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
How to recharge the Apple iPod Shuffle Silver MP3 Player
According to the manual found here: http://manuals.info.apple.com/en/ipodshuffleuserguide.pdf
"Remove the USB cap and connect iPod shuffle to a high-power USB port on your
computer. The battery status light on the back of iPod shuffle turns on.
The iPod shuffle battery is 80-percent charged in about two hours, and fully charged in
about four hours.
When the battery is charging, the iPod shuffle status light is amber. When the battery is
fully charged, the light is green until you disconnect iPod shuffle. If you don't see the
status light, try another USB port on your computer"
Batteries also wear out from time to time, so if you find that it's not charging no matter what you do, it's likely that you need a new battery. Here's a link to more info on iPod batteries: http://www.apple.com/batteries/ipods.html
May 10, 2011 | Apple iPod shuffle MP3 Player
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
How do i turn on my ipod shuffle?.......and how long do i charge the battery for?... and how do i know my ipod is fully charged?
  • first i will cover turning the unit on. then i will cover how to charge the unit.
    -Move the power switch on the top of the iPod Shuffle to the "Normal" or "Shuffle" position.
  • Press the play button on the iPod Shuffle to begin music playback. If the iPod does not begin to play, follow the rest of the instructions.
  • Plug the iPod USB cable into the bottom of your iPod Shuffle and then connect the other end of the cable to your iPod power adapter.
  • Plug the iPod power adapter into a standard electrical outlet to charge the iPod Shuffle's battery. Try to press the play button again.
  • Connect the iPod Shuffle to your Mac or PC computer using the iPod USB cable. Then, open the iTunes program on the computer and sync your iPod with your music library. If your iPod Shuffle was frozen, it should now turn on.
  • to tell if the ipod shuffle is charging. Eject iPod shuffle in iTunes, but leave it physically connected to the USB port. The front LED should be orange if it's charging (or green if it's fully charged). If it's not charging (such is the case if it's connected to a low-power USB port on a keyboard), you won't see a front LED. If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
    Aug 25, 2010 | Apple iPod shuffle Second Gen. Silver (1...
    Ipod shuffle 2nd gen problem
    Remember these five basic suggestions if you have a problem with iPod shuffle. Try
    these steps one at a time until the problem is resolved. If one of the following doesn’t
    help, read on for solutions to specific problems.
    Reset iPod shuffle by turning it off, waiting five seconds, and then turning it back on
    again.
    Retry with a different USB port if you cannot see iPod shuffle in iTunes.
    Restart your computer, and make sure you have the latest software updates
    installed.
     Reinstall iTunes software from the latest version on the web.
     If the status light blinks orange when you press a button, the iPod shuffle buttons are
    disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
    blinks green.
     Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
    battery may need to be recharged.
    Turn iPod shuffle off, wait five seconds, and then turn it on again.
    You may need to restore iPod shuffle software
    May 31, 2009 | Apple iPod shuffle Second Gen. Silver (1...
    I Pod shuffle (2nd. generation) won't hold a charge
    Hold in the play button for 10 seconds to reset. If that fails:
    iPod shuffle Software Update and Restore
    Apple periodically updates iPod shuffle software to improve performance or add
    features. It is recommended that you update your iPod shuffle to use the latest
    software.
    You can choose either to update or to restore the iPod shuffle software.
    If you choose to update, the software is updated, but your settings and songs are not
    affected.
    If you choose to restore, all songs and data are erased from your iPod shuffle. All
    iPod shuffle settings are restored to their original state.
    To update or restore iPod shuffle with the latest software:
    1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
    has the latest software for all models of iPod.
    2 Double-click the software install file and follow the onscreen instructions to install the
    iPod shuffle Update.
    3 Connect iPod shuffle to your computer and open iTunes. The iPod Updater application
    opens.
    If you’re using a Windows PC and the iPod Updater application doesn’t open
    automatically, you can find the updater by choosing Start > All Programs > iPod.
    4 Follow the onscreen instructions to update or restore iPod shuffle software.
    If you use the iPod Updater application and it doesn’t see that iPod shuffle is
    connected to your computer, turn iPod shuffle off and turn it on again.
    Mar 15, 2009 | Apple iPod shuffle Second Gen. Silver (1...
    My iPod shuffle will not charge
    If iPod shuffle won’t turn on or respond
    â If the status light blinks orange when you press a button, the iPod shuffle buttons are
    blinks green.
    â Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
    â Turn iPod shuffle off, wait five seconds, and then turn it on again.
    â You may need to restore iPod shuffle software. See “Updating and Restoring
    iPod shuffle Software” on page 26.
    Jun 25, 2008 | Apple iPod shuffle MP3 Player
    My 1week old ipod shuffle 2nd gen wont turn on
    i got mine downloded music listend to if for about 2 weeks mabye and it was all fine..The i went to use it the next day it it wouldent turn on at all i tried to reset it adn all but nothing works....im useing windows vista so no problem there but on the ipod theres not lights and it seems to get hot while charing for a small amount of time..lets say maye 30 mins its pretty warm...is this a li po battery problem or what?
    Aug 30, 2007 | Apple iPod shuffle Second Gen. Silver (1...
    IPOD doesnt turn on
    http://www.apple.com/support/ipod/five_rs/shuffle/
    Dec 19, 2006 | Apple iPod shuffle MP3 Player
    Apple iPod shuffle MP3 Player Logo
    217 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Nagendra Baliga
    Computer Repairing
    Computer Repairing
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
