Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Mr slim mitsunishi unit wont turn on after a power outage. Checked breaker box, remote batteries and EOS emergency operation switch on unit.
  • 1,284 Answers
Hi, after a power outage, normally as power comes back in, it's a little bit high than normal. With a dead set that you got, it would probably be the control transformer. The primary could have been burn by a spike voltage.
(sudden rise in voltage above normal).
Or it's likely to be a fuse problem. Check first the fuse, if the fuse is o.k, then it would be the transformer.
Take care
Posted on Jun 05, 2010
  • patsy_wright Jun 05, 2010
    is replacing the transformer an expensive repair?
  • Shehu Pro
    Shehu Pro Jun 05, 2010
    Replacing the transformer should be around $50 to $80 which i believe you can afford....
Power outage happened now power is on and no power to mr, slim .. main unit and wall mount no power ,, fuse box has no tripped fuses
Check the disconnect at the outside unit, little box on the wall. If not, turn power off and remove top to outdoor unit.
Apr 15, 2017 | Heating & Cooling
How do I get MR Slim out of standby mode
if unit is hard wired try turning circuit breaker off and then back on
Feb 14, 2015 | Mitsubishi Electric Mr Slim E12C26426...
We have a quad mitsubishi mr slim unit. one of the units was on during a power outage. We were not home so we did not see what happened but when we returned, the unit that was left on has the vent still...
Try to turn all of the power off for a few minutes and then turn it back on...this should reset everything again...
If not you will need to get a tech. to check it all out...
Here is a tip about Mitsubishi Air Conditionersand how to get the manuals for all of the Mitsubishi line. The manual includeboth troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Jul 24, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Had a short power outage now the unit will not run. breaker ok and 234 volts to outside unit but inside unit will not come on. is there a reset or something
Try turning the unit off at thye meter box or the isolator switch out next to the outdoor unit of the air con. Leave off for 15 minutes and then switch back on again. Some Air cons get screwed up with power surges... Leaving off at the mains for a while often resets them. If the air con was running at the time the power went off, it may have damaged one of the electronic boards... Do you get any flashing lights or displays showing what could be an error code ??
Jul 16, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
We have a Mitsubishi Mr Slim air conditioning unit, i've checked the circuit breaker, the remote works but the unit will not engage.
DOES IT DO ANYTHING I THINK ON THE RIGHT SIDE IF YOU HAVE YOU BOOK IT FLASHES ERROR CODES IF YOU HAVE THE COVER OFF
Sep 18, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
The unit does not respond to the remote, it seems that there is no power going to the unit. Have checked the service panel, replaced the bateries in the remote and I have tried the emergency start in the...
Check fuse in the AC machine panel. If power is available and still it does not respond, may the micro controller or infra-red receiver problem.
Take assitance from the service provider
May 27, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim msz-a17na won't turn on after power outtage
with a dead set that you got, it would probably be the control transformer. the primary could have been burn by a spike voltage.( sudden rise in voltage above normal).
or im sure it has a fuse. check first the fuse. if the fuse is ok, then it would be the transformer.
tnx 4 using fixya,
Drcool
Nov 25, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim Issue
Need to know the year of the system, I would reccomend going to www.mrslim.com and looking up your unit. You will be able to get the full service manual for it
Aug 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Vane control on Mr. Slim Remote
Pls put the vane on the position 2 and then manually turn the vanes to desired position it will not move until the time you turn the power off and you can enjoy the benefits of Mr slim....
Jul 30, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
114 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
