Question about Mtd 22" Yard Machine Push Mower
I am trying to change the oil and now that I found the recessed square nut underneath I don't know if I need a special wrench or not. It looks like you need a type of allen wrench only square. What am I missing
  • 36 Answers
You can use a 3/8 in.ratchat extension or 1/2 in.
Posted on Jun 05, 2010
Where is drain plug to change oil 875 Briggs's and Stratton on my scottbonner mini rider
Most B & S engines have a drain plug at the bottom of the engine underneath . It is usually a square looking nut different from the rest. Check on the side of engine as well for a square looking nut as well.
Dec 02, 2016 | Garden
Show me where the plug is for the oil change
The plug is on the crankcase - the oil pan. You will find it on the bottom of the oil pan, or at the bottom edge -front, side or rear.
Depending on what sort of vehicle you own, the plug may either be a square peg, a normal 'nut shape or it may be a recessed fitting - square or hex.
The link below will give you a general idea of where to look and what to look for.
oil sump plug Google Search
Feb 25, 2016 | Cars & Trucks
Do you need a special tool to change to oil filter
Yes, but its not that special. Available from BMW parts specialists in the UK (motobins, motoworks etc). Dont try to remove the filter without one. The filter is recessed into the sump, and prevents access with a strap wrench. Dont be tempted to put a screwdriver thru the filter either.
Jun 16, 2010 | 2004 BMW R 1150 RT (ABS)
Leaking hose in between power steering pump and rack and pinion
everyone one i have taken off all i have used is a line wrench
May 11, 2009 | 2004 Ford Ranger
How to change the oil filter on an 2005 audi A3 2.0L Fsi
There should be a square hole for a 3/8 ratchet or a octagon for a wrench to remove th adapter. Some had allen wrench fittings which would be a recessed octagon
Apr 29, 2009 | 2005 Audi A3
Oil change on a tundra
No special wrench needed for filter.
The oil filter is located in the front of the engine on the right side, down at the bottom.
It's easier to change the filter by taking of the front skid plate underneath. You'll need a 12mm socket to take it off.
If you try to get it from the top, you'll get oil all over the skid plate and have a big mess to clean up. Plus, you may damage the radiator by leaning on it.
Apr 16, 2009 | 2007 Toyota Tundra
Unable to remove power steering hose where it connects underneath
They make special wrenches for removing these kind of lines, there should be 2 parts to that line, a bigger nut and a smaller nut, the smaller nut threads into the bigger nut, 2 different size wrenches are needed for this removal, go to your local parts store and explain what your trying to do, these guys will sell you the proper wrenches for the job and the proper replacement part, its not a hard job but pay close attention wehere everything goes back as your removing the defective part.. good luck....
Mar 17, 2009 | 1994 Ford Crown Victoria
Wrench support
impact wrenches are often misused by those who don’t know about their special needs. First of all, it is very important to be careful when tightening a nut or bolt with an impact wrench! Cross threading can occur very easily; a novice may also over-torque a bolt or a nut if they don’t know when to stop. To prevent such problems, always be sure to hand-tighten every nut or bolt before using the impact wrench; if you try to start the nut or bolt with the impact wrench, you won’t be able to feel if the threads are crossed. If the impact wrench is not torque controlled – meaning it will stop when the nut or bolt is tightened to a certain torque – you will need to go slowly, and periodically check the torque value of the nut or bolt to make sure you haven’t tightened it too far.
Aug 27, 2008 | Campbell Hausfeld 1/2" Impact Wrench
Mtd 22" Yard Machine Push Mower Logo
93 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
