Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
Kitchen sprayer/diverter diverter to sprayer does not divert all the water,some water still runs out of faucet head on kitchen faucet
  • 349 Answers
Http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/marielle/mar026-4n/26548-0500.pdf
Page 2 on this web site has the diverter listed. Sounds like the diverter is sticking or hanging up and not working right. The link below has information on the faucet you have so I hope this will be helpful for you.
First you could take it off and clean it and check it out for any blockage.
http://www.pricepfister.com/product_catalog/document_search_results.aspx?doctype=15&room=kitchen&collection=Marielle
Posted on Jun 06, 2010
How do I replace/repair the sprayer diverter valve in a Tuscany kitchen faucet?
Do you have a model # ? Normally the diverter will be exposed by removing the spout.
Dec 23, 2014 | Plumbing
Diverter
Hi! Yes it sounds like the spray diverter needs replacing. Kohler .com will have this part online or you could try a plumbing supply shop.
Mar 29, 2014 | Kohler K-10413-VS Forte Single-Control...
American Standard Kitchen Faucet Low water flow
I had the same issue with an American Standard faucet that I installed new 6 months ago. The diverter can be the issue if you have a sprayer attachment. Try unscrewing the sprayer head from the hose it's attached to. Now run the water full pressure with the hose pointed into the sink, obviously :~). After running the water for about 1 minute, connect the sprayer head back onto the hose, make certain the flat rubber washer and ring gaskets are seated in their grooves properly, and tighten until you have no water leaking from the sprayer head/hose connection. Now try the water through the faucet. If the problem was a temporary diverter issue, your pressure should be fine now. Good luck
Oct 31, 2011 | American Standard Kitchen Faucet 6310 020...
Installed new kitchen fauce. no water running though faucet but is running though sprayer. what could be the problem?
Sounds like the diverter that transfer water from faucet to sprayer is bad or stuck. Try turning water off and removing handle and remove spout to acess the diverter is near the base of the body of the faucet. Below is a link with a exploded view that will show you a parts breakdown hope this will help.
http://www.moen.com/shared/pdf/ca87530pt.pdf
Jun 26, 2011 | Moen 87530 Touch Control Single Handle...
Water comes out of kitchen tap then slows down to nothing at all comin out
If the aerator is clear of debris, there is a valve of sorts in the center of the faucet that diverts water to a spray nozzle (the sprayer on a hose that would be next to the faucet). Even if you don't have the sprayer, most all kitchen faucets have this diverter valve. It's a bit like the thing (in a bathtub/shower combination) that switches the flow from the tub spout to the shower head.
Sometimes, something will work its way into the diverter so that it stops the flow to the tap. It could be a piece of debris (mineral flake, rust flake, etc.) that can be backflushed out. This would require removing the faucet and removing the main valve assembly. Long story short, think about replacing the faucet if the diverter valve is acting up.
Mar 12, 2011 | Washing Machines
When we squeeze the handle of the side sprayer, only about half of the water flow is diverted through the sprayer. The remainder continues to flow through the faucet. I replaced the cartridge but the...
yes.
there is a "diverter" under the spout. you have to remove it to replace the diverter. should also replace the o rings at the same time. make sure everything is clean when you put everything back together and use a non silicone lubricant on all the parts and o rings.
Aug 15, 2010 | Price Pfister 34-3LC Genesis Kitchen...
Moen kitchen sink faucet side sprayer is stuck on
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
May 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
No water flow in kitchen sink
Sorry to say, you will need to replace that faucet, and also when you are shopping for a replacement, inquire about a rosette to cover the hole left by the voided sprayer.
Good luck...
Feb 24, 2009 | Home
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
927 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
