Question about GE 30 in. JGP337 Gas Cooktop
One ignitor on my GE jgp337 clicks once every couple of minutes continuously. What can I do?
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
I have ge jgp337 . My gas stove started ingniting without turning the burners on and all flame started coming out from all 4 burners. i switched off the electric switch now even after 2...
I've seen this problem before. It happens when spillage get's into the ignitor switches. The switches are mounted on top of the gas turn-on valves. You have to replace all the ignitor switches because they are connected into wire harness. Rich
Aug 15, 2010 | GE 30 in. JGP337 Gas Cooktop
The electronic spark continues after the burner is lit. It continues even if the burner is turned off. this continues for about a minute before it stops
You have one of your spark switches sticking. It may have come loose or possibly grease has migrated into it.
Remove the switch panel and check the switches for a loose or broken switch.
There is a switch behind every surface burner knob.
They must be seated firmly to work correctly.
Nov 26, 2009 | GE 30 in. JGP337 Gas Cooktop
Ge jgp337 ignitors continue to click after gas ignites
You have a bad ignitor which will have to be replaced. Unplug one ignitor at a time until you find the faulty one.
Jul 24, 2009 | GE 30 in. JGP337 Gas Cooktop
Gas burner will not completely lite
Call GE answer center 1-800-626-2000 aek for tech help. Have you Model # off your data plate ready.
May 09, 2009 | GE 30 in. JGP337 Gas Cooktop
Ingiters don't work - all burners
Unplug cook top. remove drip pan with screwdriver. Use hair dryer to completely dry area that might have gotten wet during cleaning. This may take five minutes. Put unit back together and plug in cook top.
Apr 27, 2008 | GE 30 in. JGP337 Gas Cooktop
Starter keep trying to start when cook top is off.
If you have recently cleaned unit and got moisture behind knobs, this may stop when the spark switches dry out. If not you will need to replace spark switches behind the knobs.
Nov 14, 2007 | GE 30 in. JGP337 Gas Cooktop
Burners only work half way
Remove the burner knobs, inside of each shaft is a straight slot screw adjustment, use a flshlight to see it. Sears has screwdrivers this small.While holding the shaft with a pair of pliers turn the screw in the shaft, it will be hard to turn, this is normal.
Continue doing this until you obtain the desired flame setting.
Oct 11, 2007 | GE 30 in. JGP337 Gas Cooktop
GE 30 in. JGP337 Gas Cooktop Logo
134 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
