Question about Asko T701 Electric Dryer
We have an ASKOT701 electric dryer with a broken belt. Can we replace this ourselves?
    Sergeant:
  • 351 Answers
You may be better getting asko to replace it,they can be difficult to get back together
Posted on Jun 17, 2010
How do you open the Frigidaire affinity dryer bc i think the belt is broken
If the belt is broken dryer will not tumble, you can turn drum and should be resistance to turn, if turns easy then belt is broken. This is a difficult repair. If you can't see how to open dryer you won't be able to replace belt.
Aug 30, 2014 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
Dryer just stopped wont turn
More than likely a broken belt. A fairly easy fix. Disconnect Dryer electric by shutting off the breaker. Then remove the front panel that surrounds the door. There are ususally a couple of screws on the bottom and you have to pot the top. Get a belt off the net or from a appliance dealer. The belt slips around the drum over the motor shaft and on a tension Idler wheel. Pop is back together and you good to go. Try checking You Tube and see if there is a video on dryer belt replacement. Good luck! :)
Oct 07, 2012 | Maytag MDE308DAYW Electric Dryer
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
Kenmore dryer will not work
the motor will make a sound if working so if heard check for a broken belt that surrounds the drum inside
May 14, 2010 | Kenmore 63942 Dryer
Dryer runs but wont tumble
Try checking to see if the dryer belt is broken, the dryer belt wraps around the drum and goes to a motor at the bottom of the dryer that turns the drum, if so you can usually get a replacement belt from the maker of your dryer by visiting there website.
Mar 11, 2009 | Danby DCD5505W Electric Dryer
2 year old Kenmore Elite Front Load Dryer makes loud squeaking
We can fix this. your dryer has some wheels/rollers and an idler pulley they get worn and or plug up with fabric sheet guu.what you do is pop the top,that the frount off and this will expose the drum,undo the belt the clean inspect /oil and replace worn parts.sounds like you wont see much wear because it stops after[gets warm]so may get buy with oil/cleaning Ps unplug before working
Dec 31, 2008 | Kenmore Elite HE4 Electric Dryer
My dryer drum stopped turning. The dryer will turn on
it does sound like the belt is broken. you will need to access the inside of the dryer by removing the front. they all come apart differently. Make and Model would help me tell you more.
Dec 26, 2008 | Dryers
Simpson Sirocco 350 Dryer not heating
there is an oval cover on the back of the dryer. Remove this cover and you will probably find a broken fan belt. A replacement costs about $20 Aus.
NOTE: If you have been using the dryer for a while in this condition there will certainly be moisture inside the dryer. Replace the belt and leave the dryer for a few days to dry itself out (motor and electricals) before firing it up.
Oct 08, 2008 | Maytag 7.0 Cu. Ft. Electric Dryer
Asko T701 Electric Dryer Logo
257 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
