Question about HP Color LaserJet 2600n Printer
I'm getting fuser error 50.2. I've replaced the fuser, but still get the error. Any ideas?
    Champion:
  • HP Expert
  • 202 Answers
Ur dc controller card faulty replace them ur problem may be resolved 100%
Posted on Jul 17, 2010
I keep getting a "replace fuser kit" message on my
If you replaced with new fuser even getting same error, then check,
>Check the fuser connector (J5001). If
it is broken or damaged, replace it.
>. Check the connector (J1025) on the
DC controller PCB.
>. Replace the DC controller PCB.
Oct 07, 2011 | HP LaserJet 4700 Printer
Getting an error code 50.9 "fuser error" went through the steps in the help screen and turned printer off/on. Help!
A 50.9 fuser error is one of the most common errors. If you get a 50.x error, you can try turning the power off and on and reseating the fuser but in almost all cases you will need to replace the fuser.
Do not forget to rate my answer
Lucas
Jul 07, 2011 | Office Equipment & Supplies
HP 4V error 50, replkaced fuser and power supply. Any ideas?
Check the fuser connectors for bent pins.
Possibly bad fuser cable assembly.
Make sure printer is powered off for 30 minutes before powering on.
Gives capacitors a chance to drain.
Jun 27, 2011 | HP LaserJet 4v Printer
When I turn the Printer on, it will initialize and then display an error message "50.7 fuser error" and will not get to 'ready mode' for printing
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board. http://printertechs.com/tech/error-codes/error-codes-50-59.php
Fuser Ref: http://computer.howstuffworks.com/laser-printer3.htm
May 05, 2011 | Computers & Internet
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | HP LaserJet 4 plus Printer
Dell 1600N Multifunction printer problem.
Fuser issues - if problem is reoccuring then you are looking at more expense, are all vents free of obstructions (folders leaning on machine sides/rear) is machine being flogged, is power supply consistent, maybe even fuser bought was faulty, many options, try doing a warranty claim on fuser or replace again, even better get another printer, welcome to our throw away world!
Oct 31, 2007 | Dell 1600n All-In-One Laser Printer
Error 50
Error 50 is a fuser unit fault code. You can take apart the fuser unit and see if the fuser lamp is functional. Also check some of the other thermal parts on the fuser. If everything checks out, you will probably have to replace the thermistor. You will need to see if it will be cost effective to replace the necessary parts (Brother parts are not cheap), or to buy a new printer. Hope this helps. Good luck.
Jun 19, 2007 | Brother HL 1430 Laser Printer
HP Color LaserJet 2600n Printer Logo
138 people viewed this question
Ben Johnson
