Question about Tecnik TKC8522 Electric Double Oven
Tecnick tck 8522/2 oven
Tecnik tkc 8522/2 bottom oven no power although top oven works fine
    Sergeant:
  • 228 Answers
Power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Posted on Jun 05, 2010
  • arabianknigh
    arabianknigh May 01, 2012
    what if the timer/control display is getting no power at all?
  • Joanne
    Joanne Nov 14, 2014
    I was just aboutto buy a new oven when I tried this advice and the oven is now working . Thanks so much !!
Does anyone know where to gets parts for this oven? Looking for the main over inner glass pannel.
Ryan
Posted on Apr 24, 2012
How or where can I get bottom oven door seal tkc 8525/2 No058587098
Any appliance store should be able the help you with that. Not a big box store. An appliance store.
Nov 13, 2014 | Tecnik TKC8525 Double Oven
Worn lettering on Technik oven TKC 8522 and 8525.
You can buy new decals for this model from Ovenlettering.
Mar 23, 2014 | Tecnik Ovens
Since a power cut yesterday, our Tecnik 8522 oven has flashing 'A' (Auto) on the clock & the bottom oven does not work. I know I have to reset the time to get te A off but no buttons work on the facia...
If you cannot change it from auto. to manual it doesn't mean you need a new oven. The electronic timer can be by-passed fairly easily by joining the active and oven load wire together..
Feb 10, 2011 | Ovens
I have a Tecnik TKC 8522 double oven - I can't get the bottom oven to heat up. When you turn it on the fan comes on, but the red light doesn't come on and the oven doesn't heat up.
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
Sep 25, 2010 | Tecnik TKC8522 Electric Double Oven
Do you know the power rating of a TECNIK TKC 1255/SS cooker
i believe this is a range oven so has gas hob top one large oven a one small oven main oven draws around 2.5 kw on fan and 1.8 on conventional elements.
May 17, 2010 | Ovens
TKC 8522/2 top oven outer door shattering
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Dec 30, 2008 | Tecnik TKC8522 Electric Double Oven
Tecnik TKC 8522 or 8525
hi if you contact tecnic should be in the manual they should be able to supply you with a new facia for the cooker good luck.
Mar 06, 2008 | Tecnik TKC8522 Electric Double Oven
Tecnik tkc 8522-8525
You need something thin and strong to slide underneath the screw head. Then turn slowly while lifting the screw head. The thread should catch and the screw should back out.
Mar 02, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Tecnik TKC8522 Electric Double Oven Logo
1,640 people viewed this question
Top Tecnik Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Tecnik Oven Expert? Answer questions, earn points and help others
