Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Ghost images in multiple colors - Philips Magnavox 9P6034C 60" Rear Projection Television
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 05, 2010
HP 2600n Laserjet Ghosting. Prints multiple, faint repeats down the page. Changed all toner cartridges, still happening
Perform fuser cleaning procedure. If not helpful, replace the hot fuser roller. When worn out it collects toner and may lead to repetitive image.
Mar 09, 2017 | HP Color LaserJet 2600n Printer
The picture has ghost images, not lining up
This sounds like a convergence problem. Use the menu functions to reset your set's convergence. If this is not enough, you may need to replace the convergence board.
Feb 17, 2010 | Toshiba 57H82 57" Rear Projection...
Only on color printing am I getting ghosting of the images. How can I adjust this?
hello,when i see one color dusting, ghosting i usually change that color drum unit.If multi color ghosting probably the transfer belt cleaner blade.thanks don
Nov 10, 2009 | Canon imageRUNNER C3200 Copier
Ghost lines horizontally (looks dirty) when making multiple copie
Check the cleaning blade of the OPC drum,the image transfer unit.
Aug 17, 2009 | Canon Office Equipment & Supplies
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Ghost Images - Pastel colored images
There are 3-4 issues in here,one of them might be a bad convertion part in there. It is not worth your time and money to guess the issue,if it is under warranty,you should take it back.If not,repair tech. would be the way to go!
solutiondoct
Nov 07, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Ghost image
You will have to replace both the convergence IC's on your TV..
Oct 23, 2008 | Sanyo PLC-XR70N 70" LCD Monitor
GHOST/MULTIPLE IMAGES AND COLORS ON MITSUBISHI WS55807 PROJECTION TV
In the menu ,,under settings usally ther a convergenge option,,what it does is realine the colors,, that should do the trick,,if your tv has that ,,good luck
Oct 05, 2008 | Mitsubishi WS-55807 TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
