Question about Aquabot T4 Robotic Pool Cleaner
My Aquabot T4 only travels in one direction. It does not go in reverse. The remote does not change the direction. In essence it climbs the wall and migrates along the top of the pool. What is the cause and what is the fix?
SOURCE: Aquabot is pushing out water but will not move to clean the pool
We've had this happen a few times because we use and abuse our poor bot. I sent it out for repair twice. Then I ordered parts. Self repair was tedious for a non-mechanical guy like me but I did it. Often it is the belts that need to be replaced. Next the rubber tracts. It's worth repairing. And worth repairing yourself if you can.
Posted on Jul 18, 2009
thepool
  • 78 Answers
SOURCE: our aquabot tips over and of course cannot run
Check the handle for water inside, common problem. Make sure no air is in the system. Remove all floats if installed inside the bag area. Make sure the top water pump is operating, that is what "sucks" it to the side of the pool.
Posted on Apr 23, 2010
ynogami21
  • 670 Answers
SOURCE: My Aquabot seems to have lost power...it moves
I think you have a bad motor it would be better to have it checked on one of their centers or by a local technician to check if it has a serious problem or if it just needs some cleaning.
Posted on May 23, 2011
Geekman
  • 32281 Answers
SOURCE: aquabot is cleaning only one area of our pool and
The pool hose that is attached to the Aquabot gets set into a pattern so it moves to one part of the pool. Remove the pool hose and rotate it approx 100 degrees and re-attach it, then it will clean the pool. You may need to rotate the hose again to get the cleaner to clean the whole pool area.
Posted on Jun 03, 2011
  • 4044 Answers
SOURCE: I am working with an
First, if this suggestion doesn't help please check teh box for further assistance as i am not trying to scam you for a few bucks, I would rather fix teh problem. My parents use one of these in their pool and when it started doing this it was a tension issue. In those gears that operate to move it around the pool, there is a tension spring that is supposed to trip when it meets resistance to put it in reverse. When that spring gets weak it stops reversing direction like it is supposed to. You will need to get into that switching area and replace that spring. They went through this same problem for a month and finally I went through and replaced the springs on a hunch and now it works fine.
Posted on Jul 05, 2011
My aquabot keeps trying to come out of the pool
Aquabots are interesting little robots! They're made to clean the entire surface of the bottom of the pool, and in regards to cleaning the sides, they are programed to climb walls, but once they reach the surface the programming recognizes the specific angle of the top and sends it back down the wall. Normally an Aquabot should never leave the pool. It should reach the surface and go back down the wall to continue cleaning. Good luck!
Pool Remodeling in Clearwater FL
Jul 17, 2014 | Aquabot In - Ground Robotic Pool Cleaner
Will not clean shallow end of pool heads directly to deep end
Make sure that the Floating Handle is locked diagonally across the top of your Aquabot's body.
Clean the Filter Bag thoroughly so that the fine particles of dirt that get trapped within the fibers of the
Filter Bag are removed. To test if the Filter Bag is inhibiting the
Aquabot's performance simply remove the Filter Bag and operate the cleaner without it. If the Aquabot then pumps
water strongly, and climbs the walls properly, the Bag most likely requires a thorough cleaning
Sep 12, 2011 | Aquabot In - Ground Robotic Pool Cleaner
Problem with the Aquabot Robotic Pool Cleaner Just
The service center is stonewalling you; contact them again and demand they look at it. The unit should run consistently regardless of water balance. Water balance will affect the lifespan for a product like a pool cleaner but not whether or not it works at all. As for climbing, water temp plays a roll but 65 should be enough...what material are the pool walls? Fiberglass or some lines are too slippery for the standard brushes to climb efficiently. The service center should be able to recommend any changes that may be required due to certain pool materials you may have. Discuss that issue further with them or the manufacturer.
John
Mar 29, 2011 | Aquabot Robotic Pool Cleaner
Spins in circle
Is this water driven? If so, lower the pressure or see if the discharge is adhustable. :-)
May 26, 2010 | Aquabot T4 Robotic Pool Cleaner
Our aquabot tips over and of course cannot run
Try the ideas given at the website: http://www.i-love-my-aquabot-automatic-pool-cleaner.com/
Shelby Christian dansker01@msn.com
Aug 04, 2009 | Aquabot In - Ground Robotic Pool Cleaner
My turbo bot does climb the walls of my pool. I have had it checked out with service. they could not find any problems. Any suggestions?
Not too uncommon. The float design is such that many units lack enough bouyancy to work well on wall climbing. New floats or added floats may help. S. Christian dansker01@msn.com
Jun 25, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Cleans only a bout 50% of my pool and doesnot clean walls. My pool shape is a foot print.
Both of these problems could be the installed floats. There are 3 of them normally installed, and they do have a finite service life. Old ones often absorb water, making the unit not cover the full pool area or climb walls, S. Christian dansker01@msn.com
Jun 15, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Won't go in shallow end to clean
If your floats have started to absorb water, the unit may become reluctant to climb the slope from the deep end to the shallow end, although it may still at least start to climb and clean the wall. There are 3 installed floats in the unit bottom plate: 1 "h" float and 2 pocket floats. Aqua Service Distributors in Sequin, TX had a good price on replacements. Good people, too. S. Christian dansker01@msn.com
May 31, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Aquabot Turbo T won't climb
1.`. Replace your old, water logged floats. They will dry out when the unit is out of the pool, and the unit will work fine until they water log again, which may takes as few as 10 minutes in the pool. 2. Stop using all those words *********** didn't teach you and probably didn't even know...This is a common problem. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/ gives some really good insight, too! S. Christian dansker01@msn.com.
May 11, 2009 | Aquabot Turbo T
Aquabot T4 Robotic Pool Cleaner Logo
162 people viewed this question
Top Aquabot Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
