Question about Durabrand BH1304D 13" TV
Durabrand 13 in trying to hookup gamecube
The tv has the video and audio inputs on the front. when i plug them in all i do is hear the game but do not get the pichture. The tv is on AUX. When i plug the gamecube anywhere else it works. Am i doing something wrong?
  • 156 Answers
If the TV says AUX it might be trying to use the S-video if you have it. Try wiggling the Yellow video input while its connected... something might be lose my neices Durabrand does this. Do you have the remote still that has the GAME button on it? If not 3 digit code 189 works for Durabrands
Posted on Apr 30, 2008
Snes no sound
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 31, 2012 | Nintendo Super NES Console
My n 64 has audio but no video
Turn the power on.
Dec 25, 2012 | Nintendo 64 Console
No audio video
NES AV to TV Hookup
Note: This type of connection is not possible with the newer-style NES.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the AV cable into the Video "in" on the back of the TV. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
On the other end of the AV cable, plug the yellow end into the "Video" (yellow) input. Plug the white or red end into the "Audio" (red) input, on the back of the NES.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Press the Power button in on the front of the NES.
Turn on the TV and locate the input select. It is often called: TV/Video, input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Jun 05, 2012 | Nintendo NES Console
No video or sound
External Speakers
Installation steps:
Turn the power on.
Dec 27, 2011 | Nintendo Super NES Console
I would like to play my Nintendo Gamecube. I have a Vizio HDTV. I also have a pdp cable the will connect to my Gamecube and TV. The cable has a blue plug, a green plug, a white plug, a yellow plug, and...
What you are trying to do is run your GameCube into the component hookups into the TV. What I would do first is lay out the five plugs on the end of the cord without them crossing over eachother. There should be a red plug directly next to the white one. The red one and the white one are both your audio hookups, plug them into the audio connections on the TV (that is the L and R ones and they are color-coded). The other three (green, blue, and the other red one) are the ones that are used to display the picture. Green goes into Y, Blue goes into Pb/Cb and Red goes into PrCr (again, the connections and the inputs on the TV are color-coded to make it easier). With that you should be able to play the system. If that doesn't work, make sure the red ones are in the correct place. Good luck!
Jun 29, 2011 | Nintendo GameCube Console
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
Turn the power on.
Feb 10, 2011 | Nintendo 64 Console
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
I dont understand how to plug the gamecube into the televison or the dvd player?
Quick Tip! If your system is connected using AV cables or the Component Video cable and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
If this is your first time connecting your system, we strongly suggest you verify your hookup before continuing with the blank screen troubleshooting.
Are you using any accessories that didn't come with your system? Unlicensed products are not fully compatible and may not work correctly.
With the power ON, open the Disc Cover, remove the Game Disc, close the Disc Cover and turn the power OFF and then ON. If the Main Menu appears, your disc may be damaged or dirty.
Check your system connections and ensure they are all firm and correct:
Stereo AV cable
Remove the plugs and reinsert them with a slight twisting motion. Make sure that you are plugging the yellow cable into the video input. Also ensure that your audio cables (red and/or white) are plugged into the audio input jacks on your TV or VCR.
Component Video Cable
Remove the plugs and reinsert them with a slight twisting motion. Make sure that you are plugging the green plug into the green input (labeled Y), the blue plug in the input (labeled Pb or Cb) and the red plug into the red input (labeled Pr or Cr). Ensure that your audio plugs (red and white from the Stereo AV cable) are plugged into the audio input jacks associated with the component input jacks and that the yellow plug is hanging, and not plugged in.
Check to see if the game you are playing is set to progressive scan mode. If it is, try changing it to interlace mode. To do this, load the game disc into the system and hold down the B Button of the controller while turning on the system.
RF Switch/Modulator
Try switching both the TV and modulator to either channel 3 or 4. Also, try disconnecting the antenna from the RF Switch.
Common Solution: For RF connections, we find that video problems occur most often when an unlicensed RF switch and modulator set are used. Make sure your RF switch and modulator set are two different pieces and the name "Nintendo" is molded onto the RF switch and modulator. If your RF modulator is one piece or is black and it says "for use with Nintendo" it is an unlicensed product. Unlicensed products are not fully compatible with our systems and may not work correctly.
Adjust the vertical or horizontal hold controls. This is helpful even if regular TV stations come in fine. If your TV has an automatic fine tuning control (called AFC or AFT), turn it OFF. Use the manual fine tuning dial to adjust the picture. If turning OFF the AFC/AFT causes your TV to display in black and white, then leave the AFC/AFT ON. Slide the Power Switch on the Control Deck to the ON position, while the Control Deck remains ON, turn the TV off for 10 second then back on again. This resets your AFC/AFT so that it will tune in the signal from the Control Deck.
Move your Control Deck farther away from your TV. If the Control Deck is too close to the TV, the Control Deck may cause some interference.
If you're using the AV cables or Component Video Cables, verify that your TV or VCR is on the correct the input select.
If your TV has a closed captioning option, make sure that it's turned off.
Check the game manual to see if the game has any special features that might appear as a problem.
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If these steps do not resolve the symptoms you are experiencing with your system, check out our convenient repair options.
Nov 27, 2010 | Nintendo GameCube Console
Can i hook up PS2 using only the white and yellow jacks?
i download and read your owner manual .
http://www.funai-corp.com/6pdf/om/DWT1304.pdf
i do see you only have a video and a mono sound input jack , so , your ps2 as in all RCA style jack inputs , yellow is video , red and white is audio , i will assume you have yellow plug in video and red or white in audio , and on your TV remote you hit the GAME button , i'm suprised they don't use the term VIDEO , but , anyway , are these the steps you have taken ?
Dec 30, 2008 | Durabrand DWT1304 13" TV
Durabrand 13" tv model BH1304D
You will need the original remote control I,m afraid. The original remote is the Durabrand HYF-23A. On the original remote, incase you do have one, is a button marked TV/AV. That is the button that changes between the TV and the Audio/video inputs. An original replacement remote can be purchaed HERE: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=BH1304D&brand_pn=DURABRAND_BH1304D&mode=large&uid=11831222740150 Good Luck
Jun 29, 2007 | Durabrand BH1304D 13" TV
Durabrand BH1304D 13" TV Logo
152 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
